Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
- Use automatic dishwashing detergent only.
- Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
- Store tightly closed detergent in a cool, dry place.
- Fresh automatic dishwasher detergent results in better cleaning.
- Add detergents just before starting the cycle.
- The amount of detergent to use depends on the hardness of your water and the type of detergent.
- If you use too little, dishes won't be clean.
- If you use too much in soft water, glassware will etch.
- Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
- Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
