Question about Reddy Karosene / Desel Forced Air Heater w/Wheels
Heater will not ignite when plugged in fan will run it trys to light i think its not getting any fuel to light when fan stops heater shows E 1 on the gauge
Posted by ldhess5 on
Jerry Magee
  • 232 Answers
The heater has a photocell & control board. The safety system is not allowing the heater to run because ALL systems are not functioning properly. The control board shuts the heater down after 5 seconds if the system is not operating at 100%. Most of the time the problem is a simple adjustment, but don't adjust anything without knowing EXACTLY what you are doing.
Suggestion- If you are going to do a DIY repair then send ReddyParts.com an email, request troubleshooting tips for the HSI type heater. Be sure to send correct model of your heater. Without the correct model you may not get a reply.
Posted on May 24, 2011
The heater fan runs for about 5 seconds , does not heat and than turns off.
This could be several problems. Check your fuel first. If it is old fuel from last year, get rid of it and fill with fresh. If it has water in the tank, your spraying water to your ignition source. If you have fresh fuel, it could be a fuel filter stopped up or your air pump is not set properly. Also check your ignitor to see if it is working properly. Some have a spark plug and some have a glow type ignitor.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
When turning on My dyna pro 6500 heater. The fan will kick on for about 10sec then it will shut down and the red light will blink. How do I fix it
I have several of these in my shop. When they act up it is usually carbon deposits blocking the fire eye. This is a sensor that detects flame, if no flame is present it shuts down the whole heater. Remove the upper cover of the heater and attempt to start it, watch for 1- spark from the ignition sorce 2-fuel being sprayed from the atomizing nozzle 3-ignition of fuel. No spark bad spark plug or ignitor, no smell of fuel or small cloud of fuel, bad fuel filter, no fuel, bad fuel line, bad or plugged nozzle. There are several things that cause this but these are the three most common problems I encounter.
Dec 10, 2010 | Desa International R40 Utility Heater
When plugg in fan turns about a 1 second and stops. Used to work fine last year actually used it couple times this year too what seems tobe the problem thank you
sounds like an ignition problem. The fan is supposed to start first to get the airflow going, then the igniter should heat up (glow igniters) or start sparking (spark plug igniters), then the fuel starts pumping. If the igniter is not working the fuel won't start. Things to check.... igniter - see if it is intact, fuse (usually in the circuit board), If those are ok, then check fuel pump, fuel filter, air filter. Hope this helps.
Jan 12, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heter trys to ignite,replaced igniter,cleaned fuel filter
1. Check the ignition transformer. It may be grounded,
or it could be defective, and need to be replaced.
2. You have already replace the igniter and the
photoeye.
3. Once the ignition transformer works, everything will
be alright.
May this tip help you.
Jan 04, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
My car wouldn't start once in a while, mechanic checked it and says diagnostic report shows nothing wrong with car but thinks it may be fuel pump.
Here are a few possibilities: 1) Fuel Pump and/or connections to it. 2) Ignition switch 3) Starter/solenoid 4) Security system - if equipped
If, when it won't start, you get ignition lights on the dash, then listen to hear if the fuel pump runs. It should run for a bit and then stop. If it doesn't run - then look in the area of the fuel pump and wiring. I had one where the fuel pump ground was loose and it would do this about once a week. If the pump runs, then look at the wiring and solenoid.
If you don't get any instrument lights with the ignition on, then you need to look at the ignition circuit. I had a case like this and it turned out to be a bad ignition switch - very intermittent.
Nov 04, 2009 | 2004 Pontiac Grand Am
Trys to fire up then after about 8seconds then
overheat stat or fan check little tube at fan area for pinhole best of luck
Nov 01, 2009 | Rheem RTG-53XP Outdoor Liquid Propane...
Heating & Cooling Logo
69 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
