Please remove you memory card and make sure with a scan on your PC- insert into the card reader - if there are any errors , malwares on files loaded. If so remove and format and copy only safe files. Also clear the cache and browsing data, clear the camera and aaudio content. Try and reset the phone to default factory settings ,If not there can fault within the board or memory and must take consensus.
It is possible that the phone is slow as there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is confirmed that the software has errors and will need a reinstallation.
Your phone memory system is overload. Delete all cache from your browser. Install powerful anti virus and do some scan. If its persist, reset your phone to factory setting. Start with soft reset, if it doesn't work, do hard reset to your phone. Don't forget to put off your memory card before resetting.
I would start off by doin a internet search for samsung s5233a hacks . See if it dont come up with some helpful stuff. also Check samsung website for solutions.check for common problems online with your make and model cell ,,others may have had that happen also..may have solution you need,,thanks and goodluck
