Cant record two programmes at once - Televison & Video
Posted by aaron_ruddy on
  • Gale Todd May 14, 2011
    What make and model DVR do you have?
Rocky Murphy
    New Friend:
  • 24 Answers
Well no matter the DVR, you should be able to record 2 programs at once...but you CANNOT watch a 3rd live while they are recording...also, if your DVR is hooked up to more than one tv and someone is watching something else in the other room, it will not record 2 at once, either. You can watch RECORDED programming while 2 others are recording, but not live tv.
You might want to check how many "inputs" your DVR has...most have 2 which allows the double recording...if you have an older DVR maybe you only can do one at a time. On my DISH box, they call these "TV1" and "TV2".
Hope this helps.
Posted on May 14, 2011
Lg dvd recorder wont record get message "service unavailable or scrambled"
It isn't programmable, once you have it wired to the TV you select function display and it should program itself if properly connected.
Sep 01, 2012 | LG Televison & Video
After recording a programme it stops half way through when playing it back this happens occasionally we are unable to carry on with the recorded programme once it stops
Try to play a couple of dvds on another dvd player thru the point yours stopa to see if the recording is bad or the player portion is defective. Also is unit under warranty?
Sep 14, 2011 | Televison & Video
Subtitles appearing on screen in recording mode on LG RHT497H
You are confusing subtitles with closed captioning (CC).
Nov 19, 2017 | LG RH177 DVD Recorder/HDD Recorder
Recording and actually WATCHING the programmes I record
this feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
Mar 15, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Vn - 2100pc olympus voice recorder
I had the same problem with the VN-4100PC and 64-bit Vista, and have solved it by accessing the recorder under Windows XP in a Sun VirtualBox. This will probably work for the VN-2100PC
Nov 04, 2008 | Olympus VN-2100PC Digital Voice Recorder
Any clues on how to copy multiple programmes from my hd to a dvd?
Depending on the DVD Media used.
If you used DVD-R Or DVD+R, then these are write once Only.
Once data has been written, and finalised by writting the Table-of-Contents to the Disk. Then no-more can be added. Hence read-Only.
If you use RW/ DVDs then they can be written to several Times. Although your Player may insist on you Formatting/Erasing any previous Data from the Disk. Before re-writing.
If you are using Write Once only media i.e DVD-R Or +R.
Then it would be a good suggestion to write approximately 4 gig of data Or between 2-3 Hours Of entertainment, to 1 Disk.
Re-Writables are the Practical option For You.
Mike @ compurepair.
Feb 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Record at once on dvd?
No direct record from TV to DVD on this model, yes it is very annoying...
Jan 16, 2008 | LG RH266 Recorder
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
