Question about Logitech Z-2300 Computer Speakers
My Logitech Z-2300 left speaker is not working what can I do?? There is no sound coming out of it
Posted by ruffles_rafa on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Try to check your setting of your speaker maybe theres something wrong in your settings
Posted on May 13, 2011
I have actually lost my satellite speakers that came with the Logitech Z-2300. I am wondering what my best option is. I can't seem to find anyplace that sells these kind of speakers separately. I...
Hi
http://www.livedigitally.com/2005/09/05/logitech-z-2300-speaker-system/
It would appear you need 2 x 1/4 inch (3.5mm) jack to RCA cables, one for each channel and each speaker, left and right, rather than just the 1 cable ("..and a mini to RCA cord...") you seem to have bought.
The Yellow and Black RCA ports appear to be the Left and Right speaker channels respectively.
The output cable with a green jack that connects to the green jack on the computer's sound card seems to be tied in with the wired Remote Control.
I would have recommended getting a pair of passive 40W RMS Logitech Stereo Speakers.
As long as the speakers you have match in terms of Wattage and Impedance, you should be okay.
I hope this helps.
Z-2300 left speaker not working
First try to setup your operating system sound setting in control panel. check if drivers are installed properly or try updating them.
if problem still there may be the plugs to the woofers is not working correctly.
If it is warranty period change them as fast as you can.
Logitech z-2300 stop working, there is no sound coming out off the speakers anymore
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
The left satellite has stopped working, sound does not come of it. The left one works fine and so does the subwoofer, however the on left one not working is becoming very irritating.
Have you checked if the amplifier is working??? Maybe the saund generator (Compiuter, TV etc.) is set to only play on left, check balance, and CHECK THE CABLES
1helpful
Logitech z-2300 subwoofer not working
ahh logitech always the sub that goes. its buggered but dont toss out the whole speaker set just buy another one and youl have spare speakers when you need them
I have the logitech z-2300 just the other day the
mine did the same thing today , i just bought these new 2 weeks ago . the black prong speaker works in both ports ..
the yellow prong speaker is the one with the malfunction .
it works sometimes but when i turn up the volume louder it dies out .
I have a logitech z-2300 speaker system, one of the speakers (left) sound goes in and out and has been for a while, so is not completely blown. Is there anyway to fix this before its too late...?
its a problem with the speaker, if you could possibly change out the wire, I would suggest that cause there could be a break in the speaker.
If you can't do that then the speaker needs to be replaced.
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
1helpful
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Logitech Z-2300 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Mandeep  Singh
Mandeep Singh
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
