Question about Tag Heuer TH 5104 Sunglasses
My left side frame snapped today. I need to replace it. They are flexible dont know why that happened.
Posted by rich_fitzger on
Caroline Mizar
    New Friend:
  • 24 Answers
Good brands like TagHeuer mostly give a warranty. So look when and where you have bought them and whether the warranty is still valid. In this case its easy, you go there, make a complaint and you will get them replaced or repaired.Presupposed that the damage was not caused by wrongful usage or impact. If they are old and you don't remember where you have bought them, look for an optician who has TagHeuer glasses in his sales collection and ask whether they can be repaired. He also can give you an estimate of cost for the repair and then you can decide whether it is worth the expenses or you better buy new ones.
Posted on May 24, 2011
2003 VTX Ran Yesterday, today hit the start button and nothing happens. Had the battery checked and its good. The F1 light comes on and you here it priming but after that when you hit the start button...
sounds like you have a bad ground somewhere on the frame.I know there is a ground on the frame just in front of the battery and one on left side under front of motor factory painted the frame and they just bolted up the wires need to clean paint off and retighten. might be the problem
Apr 03, 2011 | Honda VTX 1800 Retro Spoke Motorcycles
Turn left and the engine turned off?
Most likely this is due to a loose connection or other wiring problem which is stretches when the powertrain "swings" to the right when you make a left turn. This happens because the powertrain is mounted in flexible rubber mounts to allow some motion rather than a rigid mounting to the frame.
To determine if this is indeed what is happening, with the engine running and the car parked, open the hood and give the engine a hard push towards the passenger side of the engine compartment in order to simulate the motion of the drivetrain when you make a left turn.
If the engine cuts off, you may begin looking for wiring problems in the relevant locations
Jan 02, 2011 | Ford F-150 Cars & Trucks
I have a 4 year old 40" Samsung 1080p lcd tv. The problem I am experiencing is that when I turn on the tv the picture initially is separated into 4 section horizontally. The top section is ok, the other 3...
I have a 46" Sanyo LCD TV with a similar problem. The top 4th has intermittent vertical lines and then occassionally the whole left side goes dark. There are 4 distinct sections like yours. The top section usually messes up most of the time with the other 3 just happening occasioally. I found the by tapping on the left side of the frame or squeezing the left side of the frame that it will normally start working for a while. I have been doing all kinds of research and can only find people with the same problem but not solutions. Since there is so many people with this problem I am seriously considering spending the money to slowly replace parts until I can find the cause. If tapping on the frame or squeezing on the frame or lightly pushing on the screen seems to work please let me know so when I get deeper into my TV it will help me know more what to do. You can email me at [email protected] I'm afraid it is going to be the screen. JR
Oct 12, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
The protective screen cover to our Hitachi model 51uwx20b is cracked. (collided with a Wii controller!) I know I can replace the plexiglass but do not know how to remove the broken one. Can someone give me...
Most of the Hitachi's have to be removed from the front; remove the speaker grill assembly(it usually pulls off and is held in place with plastic pegs. Once it is removed locate at the bottom edge of the screen; remove several screws(left to right) that secure it. Most of these frames are snapped in--held in place and you need to start on the lower left and then right side to pull them free---some are in very tight---take your time and pull from bottom first and then sides--a few also have a notch on top which means when the bottom and sides are free you have to lift the frame up and out a bit to get the entire unit free. They go back the same way(top edge first) and if you find the inside of the frame has some metal posts you need to tap the frame back once it is in position.
I do this here for free so if this helps you give me a vote here. If you have questions let me know here.
Aug 27, 2009 | Televison & Video
I have a Husqvarna YTH 2348 the deck anti sway bar came looses fell of frame and bent, I removed rod strightened and need to kown how to put rod back in proper location on the frame and deck bracket
Once you've straightened it - you've finished the hard part. Now take the end without the pin and stick it into the hole located on the transmission frame (the metal piece that the transmission sits on.) It is directly under the seat. The hole is on the front side of the tranny frame. Once you have it all the way in, take the pin end and put it through the mower deck brace (right side.) There is a hole there also for this end. If it doesn't go through enough to get the washer and pin through, push the mower deck towards the anti-sway bar. It should give a lot since the anti-sway bar is off. Once you fasten it, your'e done!
I only know this because it just happened to me today. I have the same mower as you, so I thought I would share.
Jun 04, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Water dispenser wont work / side by side / no voltage at solenoid/ dont know how to access door switch
It's tricky but under the dispenser frame they're 2 slots where u can fit a small flat bit screwdriver.. While pushing down on that frame use the screwdriver to pull the bottom of the frame to u. U will hear a snapping sound, that's normal. be gentle.... Mostly likely the bracket that hold the switch is broken..
Dec 24, 2008 | Kenmore 24.5 cu. ft. Side-by-Side...
Power steering fluid
Just went to a dealer today for my 2000 regal. It took them a while, but they showed me where my power steering cap was.
It is black and very hard to see. You need a small flashlight (LED recommended), and then need to look on the left side behind the engine and in front of where the glove box is. WAY down, under some hoses, and adjacent to the engine is the power steering cap (I'd estimate about 8-10" down). The best way to see it is to lean into the engine from the front while standing to the left of the center of the car. Lean forward and place the flashlight pointing down and slightly to the left behind the engine and at a level just below the block. Good luck!!
Jun 15, 2008 | 2000 Buick Regal
Red line on screen
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears. 9f78570.jpg
Nov 08, 2007 | LG DU--50PX10C 50 in. Plasma Television
Tag Heuer TH 5104 Sunglasses Logo
222 people viewed this question
Top Tag Heuer Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Tag Heuer Clothing Accessory Expert? Answer questions, earn points and help others
