Samsung 226BW Monitor Logo
Anonymous Posted on May 13, 2011
Samsung 226BW shows blue powerlight and displays "digital/analog" search on the screen for a second or two. There is a gentle electrical "fizz" sound then the screen goes completely black. I replaced the power board, althoug no caps seemed bad visually, and the unit still had same symptoms. Next, I purchased the M220EW01 VO X PCB component (inverter?). Q: How do I attach it? The eight 8 Raydium plastic ribbon connectors on the old board seems to be glued to the gold contacts at one end and disappear into the panel at the other. Are they ironed on or something?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on May 15, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366142
Points
33650
Service manual: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=226bw&kategoria=&kat2=all
I m not sure exactly which connector you are talking about.
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/SAMSUNG%20226w/
The fixxing sound can be from arcing in the lamp assembly.
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
The inverter will go inot shutdown if it senses open circuit (lamp does not fire up), or too much current draw (arcing voltage to the lamp casing).
You need spare lamps to test the inverter board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Samsung syncmaster 912T disply will disapear. moniter still on just not getting info from cpu. after it is on for and hour somtimes it will not show display
Your description suggests the fault is with the screen, not the system. Can you you test that by connecting both screens to a buddy's computer?
When first powers up display is fine suggests a bad solder joint, revealing itself after heating up.
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
5helpful
2answers
Samsung 226BW screen takes a long time to show anything
This model may have defective capacitors in the power supply. I normally replace the 2 or 4 bulging caps and normal function is restored.
Monitor Mike
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
11helpful
2answers
Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Power on but display cuts out
Sounds like the backlight's gone. You can try to open up the case and replace it, but an easier (and probably cheaper) option is to simply buy a new monitor
Samsung 226bw weird display problems
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Samsung Monitor 2232BW
consult a technician you could not do any thing for this fault
Movie on monitor
Hi, Normally I would suggest that you first lower your laptop's screen resolution, refresh rate and color quality and verify that you have enabled the external monitor or dual view in your Display Property Settings as well as the Fn key + F?. However, this kind of problem should not exist with an LCD Widescreen monitor with specs and features as your Samsung 226BW. If trying the reco on the first paragraph and you still have no movie display (but all other laptop display shows), perhaps it is a problem with the Samsung 226BW. To my knowledge, this particular brand/model uses no less than 3 different panel display, some not as good as the others. Verify that you have an original Samsung panel display in your Samsung monitor by looking at the sticker at the back of the screen, it should say Model: 226BW [R] S. If it says A or even a C, then perhaps the display panel is not living to its specs/claimed capacities. You of course can request a replacement from your dealer and cite your problem but insist that it be an "S". Most instances (but not always) an "S" would mean panel screen by Samsung, "A" by AU Optronics and "C" by CMO. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
