Connect your PSP with your PC using the USB cable. Use your PSP interface then hit HOME button, and then go into "Settings". Here you will have to use
the directional button to find "USB Connection"
Once the connection is made, you will need to check your PCs available drives. You can do this by
going into "My Computer". Your PC should detect your PSP as and additional drive.
Click on your assigned PSP drive and Create a new folder call "my music" on your PSP drive
Select your MP3 music from your PC and drag it into your "my music" folder on your PSP. Note that all
this is done in your PC interface.
When all the desired MP3 are transferred, get out of the USB connection by pressing "O" on
your PSP.
Find the music in your PSP, and select your memory stick. Search for your "my music" folder and
you are good to go.
If you have other types of music format in
your PC, i.e. WMV or WMA, you will need a converter to
convert those
files to MP3 format. You can easily convert WMA and
WMV files format into MP3 format and just repeat the whole process.
