Question about Paradyne COMSPHERE 3910 Modem
Status screen on 3910 modem
I usually select the left arrow to view settings on the 3910 modem, however on one of the 14 I have it returns to the status and configuration screen instead of staying on the screen I have selected. If I choose the configuration button it also returns to the status and configuration screen. The modem works it is just impossible to view all the configuration before the screen returns to the primary status screen.
Posted by enoch12 on
1 Related Answer
Mac hustler
  • 87 Answers
SOURCE: Modem driver on XP for : Paraydne COMSPHERE 3910
try this one but you need to register an account on it so then you will be able to download drivers for ya modem
http://members.driverguide.com/driver/detail.php?driverid=3273
peace!
Posted on Jul 04, 2008
Well i tried to connection my internet but it will not go
hi daphne, follow these steps it shud work
The Nintendo Wii system is changing
how people game by swinging people
into action with their motion activated
controlled. Share the fun of this system
by connecting to the Internet. Gain
more functionality out of your Wii by using it for things like browsing the
web, receiving updates, and
downloading games. Difficulty: Moderately Easy Things You'll Need: Nintendo Wii High-speed internet access Wireless router Nintendo Wii LAN Adapter Ethernet cable Router or modem PC running Windows XP Nintendo Wi-Fi USB Connector Instructions Connect a Nintendo Wii to the
Internet through a Wireless Router 1. Turn on your Nintendo Wii by
plugging it into a power source
and pressing the power button. 2. Press the "A" button on your Wii
controller to continue from the
warning screen. 3. Select "Wii" button in the left
hand corner of the main menu,
by using your Wii remote to
move the hand shaped cursor
over the "Wii" button and
pressing the "A" button on the controller to select the Wii
options. 4. Click the "Wii Settings" box on
the right. 5. Select the left arrow to scroll over
to more options. Then select
"Internet" from the list and
"Connection Settings." 6. Choose an open connection by
selecting the "Connection 3:
None" option, then the "Wireless
Connection" option, and the
"Search for an Access Point
Option." 7. Choose the access point you
want to use from the list that will
be displayed. Save the settings
by clicking "OK." Then click "OK"
to start a connection test. When
the test is complete you are connected. Connect a Nintendo Wii to the
Internet with a Wii LAN Adapter 8. Insert the Wii LAN Adapter into
the USB port on the back of the
console. 9. Connect an Ethernet cable from
your modem or router to the
adapter. 10. Turn on the Wii console. 11. Click the "Wii" options button in
the lower left hand corner. Select
the "Wii Settings" option by
clicking on the left square. Scroll
to list more options by clicking
on the blue arrow to the left of the screen. Choose "Internet"
from the list of options. 12. Select "Connection Status," then
"Connection 3: None" and
"Wired Connection." 13. Click "OK" to initiate the
connection test. When the test is
done you should be connected. Connect a Nintendo Wii to the
Internet through a PC 14. Insert the CD that came with the
into a PC running Windows XP
that is connected to high speed
internet. When the setup window
appears click "OK" to start the installation. 15. Choose your language and click
"OK". 16. Insert the connector into a USB
port on the PC when prompted.
Hook the connector directly to
the PC as ports on the monitor
and keyboard will not work. 17. Click on the registration tool on
the Windows task bar. 18. Turn on the Wii console. Click the
"Wii" options button in the
lower-left corner. Select the "Wii
Settings" option by clicking on
the left square. Scroll to list more
options by clicking on the blue arrow to the left of the screen.
Choose "Internet" from the list of
options. 19. Select "Connection Status," then
"Wireless Connection." Choose
"Nintendo Wi-Fi USB Connector"
from the options list, then "Next"
to continue. 20. Return to your PC and you will
find your Wii listed in the
Registration Tool window. Click
on your Wii's name and select
"Grant Permission to Connect." 21. Return to your Wii and click
"Next" for the setup completion
window, and then click "OK" to
run the connection test. Tips
Aug 26, 2011 | Nintendo Wii Console
How do you get rid of military time on the LG start-up screen?
Hello
Enter the Menu and come to Manual Clock Setup Screen.
Press the MENU button and then use UP/DOWN button to select the TIME menu.
Press the Right Arrow button and then use UP/DOWN button to select Manual
Clock
Press the Right Arrow button and then use Left arrow/Right arrow button to select either the year,
date, or time option. Once selected, use the UP/DOWN button to set the year,
date, and time options.
Press EXIT button to return to TV viewing or press MENU button to
return to the previous menu.
On the time option, you can select itt to 12Hour or 24Hour format. OK.
May 01, 2011 | LG 42LC2D 42 in. LCD HDTV
How do I connect my wii to the internet?
hello. good day. here are procedures i got from e-how.com hope this helps:
Connect a Nintendo Wii to the Internet through a Wireless Router
1. Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
2. Press the "A" button on your Wii controller to continue from the warning screen.
3. Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
4. Click the "Wii Settings" box on the right.
5. Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
6. Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
7. Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter
1. Insert the Wii LAN Adapter into the USB port on the back of the console.
2. Connect an Ethernet cable from your modem or router to the adapter.
3. Turn on the Wii console.
4. Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
5. Select "Connection Status," then "Connection 3: None" and "Wired Connection."
6. Click "OK" to initiate the connection test. When the test is done you should be connected.
Connect a Nintendo Wii to the Internet through a PC
1. Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation.
2. Choose your language and click "OK".
3. Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work.
4. Click on the registration tool on the Windows task bar.
5. Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
6. Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose "Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue.
7. Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect."
8. Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test.
Apr 29, 2011 | Nintendo Video Game Consoles & Games
How do I hook my wii to my internet
You can hook-up your wii to the internet through any of the below method;
* 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
* 2 Press the "A" button on your Wii controller to continue from the warning screen.
* 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to
* 4 Click the "Wii Settings" box on the right.
* 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and
* 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless
* 7 Choose the access point you want to use from the list that will be displayed. Save the
* 1 Insert the Wii LAN Adapter into the USB port on the back of the console.
* 2 Connect an Ethernet cable from your modem or router to the adapter.
* 3 Turn on the Wii console.
* 4 Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by
* 5 Select "Connection Status," then "Connection 3: None" and "Wired Connection."
* 6 Click "OK" to initiate the connection test. When the test is done you should be connected.
* 1 Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows
* 2 Choose your language and click "OK".
* 3 Insert the connector into a USB port on the PC when prompted. Hook the connector directly
* 4 Click on the registration tool on the Windows task bar.
* 5 Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii
* 6 Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose
* 7 Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector
Connect."
* 8 Return to your Wii and click "Next" for the setup completion window, and then click "OK" to
Good luck.
Apr 19, 2011 | Nintendo Video Game Consoles & Games
I am finding difficulties connecting my wii too the internet
  • 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2 Press the "A" button on your Wii controller to continue from the warning screen.
  • 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4 Click the "Wii Settings" box on the right.
  • 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7 Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • 1 Insert the Wii LAN Adapter into the USB port on the back of the console.
  • 2 Connect an Ethernet cable from your modem or router to the adapter.
  • 3 Turn on the Wii console.
  • 4 Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
  • 5 Select "Connection Status," then "Connection 3: None" and "Wired Connection."
  • 6 Click "OK" to initiate the connection test. When the test is done you should be connected.
  • 1 Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation.
  • 2 Choose your language and click "OK".
  • 3 Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work.
  • 4 Click on the registration tool on the Windows task bar.
  • 5 Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
  • 6 Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose "Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue.
  • 7 Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect."
  • 8 Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test.
Mar 03, 2011 | Nintendo Wii Console
How can I clear the memory on my Canon MF4350d? I'm trying to fax but the memory is full. The manual does not have the answer. Thanks
To clear memory of MF 4350d do the following
Press MENU and then # You will enter into service mode. Scroll using any of the arrow keys and press OK for CLEAR DATA Again using arrow keys scroll and select MEMORY CLEAR press OK.
Feb 28, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
There are three options available to connect Nintendo wii to the :-
Connect a Nintendo Wii to the Internet through a Wireless Router (1) Turn on your Nintendo Wii by plugging it into a power source and pressing the power button. (2) Press the "A" button on your Wii controller to continue from the warning screen. (3) Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options. (4) Click the "Wii Settings" box on the right. (5) Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings." (6) Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option." (7) Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter (1) Insert the Wii LAN Adapter into the USB port on the back of the console. (2) Connect an Ethernet cable from your modem or router to the adapter. (3) Turn on the Wii console. (4) Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. (5) Select "Connection Status," then "Connection 3: None" and "Wired Connection." (6) Click "OK" to initiate the connection test. When the test is done you should be connected.
Connect a Nintendo Wii to the Internet through a PC (1) Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation. (2) Choose your language and click "OK". (3) Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work. (4) Click on the registration tool on the Windows task bar. (5) Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. (6) Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose "Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue. (7) Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect." (8) Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 02, 2010 | Nintendo Wii Console
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
2 In Control Panel:
  • Select Display.
In Control Panel:
  • Press ENTER.
  • Press ENTER.
  • Select OK.
  • Press ENTER.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
I have a canon SD110 and can't figure out how to change date. I don't have a manual.
Manual available for viewing/download here. To change the date/time:
1. With camera on, press the Menu button.
2. Use left/right arrows to select Setup menu (icons of tools)
3. Use up/down arrows to select Date/time icon (clock and calendar)
4. Press Set button
5. Use left/right arrows to select year, month, day, hours, minutes and then use up/down arrows to set correct value.
6. When everything is correct, press Set button.
7. Press Menu button to return to normal mode.
Dec 10, 2008 | Cameras
Paradyne COMSPHERE 3910 Modem Logo
54 people viewed this question
Top Paradyne Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
