Washing Machines Logo
Question about Maytag Performa LAT2500A
I have a Maytag Performa top load washer. The agitator keeps releasing from the mechanism that enables it to agitate. It sits nicely, but does not stay put when a laundry cycle is going through.
Posted by cheryl_hamil on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Posted on Aug 16, 2007
Anonymous
  • 725 Answers
SOURCE: Maytag Performa Large Capacity Top-load Washer
the agitator should have a SCREW, AGITATOR RETENTION that holds it on ..see brakedown. unless you are talking about the DISPENSER, FABRIC it should just snap on. let me know if his helps krazytech
Posted on Sep 09, 2007
Anonymous
  • 1294 Answers
SOURCE: Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 26, 2007
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
Anonymous
  • 478 Answers
SOURCE: Maytag Performa PAVT920AWW noise in wash cycle no agitation
Your main tub bearings need replacing at least a 200.00 repair. The parts alone are about 80.00 and a few hours labor.
Posted on Mar 29, 2009
1helpful
I have taken my Maytag Performa PAV 3300AGW top loader washing machine apart after grinding noises were comming from the machine. After removing the drive pully mechanism from the agitator shaft I dis
This should fix you up nicely:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-PAV3300AGW/3048/0153200/M0604157/00004?blt=06&prst=&shdMod=
Good Luck.
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Agitator screw keeps coming out.
New parts !!
Threads are worn and will not lock
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 • Dryers
Maytag Performa top loader is making grinding noises
The agitators are a pop-on fit. Make sure that the agitator is firmly seated on the shaft. Lift it up and if it moves easily adjust it to the splines on the shaft and press it back into place.
Maytag Performa PAVT920AWW noise in wash cycle no agitation. Belt is not broken but in the wash cycle there is no agitation only a bad bearing sound.
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
1helpful
2answers
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
2answers
Does not spin
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
