Question about Black & Decker Vacuums
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Posted by kuhnau on
Canwoodjc
    Brigadier General:
  • 3,301 Answers
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
Posted on May 13, 2011
Parts manual
VacPartsWhareHouse.com has the most helpful parts manual and schematics for your model vacuum:
Electrolux EL7020A
Mar 15, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
M# 175.8590990 Broke plastic pin on P# 663513-001 angled wand that holds tube from nozzle. Sears don't have.
I need owner manual for kenmore carpet cleaner 175.8590990.
Thanks
Abrar
Jun 29, 2012 | Vacuums
The grey pre-filter catch broke and we ordered a new one. now we don't know how to install it.
I just successfully completed this replacement on a DC33 (the prefilter catch is blue on this model.) Not sure how different the assembly is from the DC07 but thought I would post: If you turn the vacuum over there are two screws that loosen the exhaust pipe--one you can see and one up a small shaft (which also loosens the cowling just under the cyclonic assembly.) Both will require a driver or allen-style wrench with a medium-sized star head. Remove both and you will be able to take off the exhaust pipe. You'll need to pull back the aforementioned cowling a bit as you do this. Once the exhaust pipe is off you will be able to see the bottom of the prefilter catch. You'll notice five tiny bays--if you shine a flashlight through you'll see that between bays 2 and 3 there is a small catch (you can note it at the bottom of your replacement prefilter catch as well.) Shove two extra small screw drivers (like the size you get in eyeglass repair kits) into bays 2 & 3, then gently press down on the driver handles to release the catch. A little pushing at the same time will remove your broken prefilter catch. DON'T INSTALL YOUR NEW CATCH YET! Otherwise, like me, you'll have to immediately remove it to reinstall the exhaust pipe :) This was the most time consuming part of the whole operation, as you kind of have to fenangle it a bit to get it back on. Be patient and don't forget to pull the cowling back again while you're doing this. Once it's back on, realign the cowling at the top of the assembly and replace the screws. Then you can turn the vacuum upright again to easily snap in your new prefilter catch.
Nov 03, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
I have a bissell powerforce bagless.that is melting belts. i've cleaned the brush bar and put a new belt on only to have the new one melted again. i don't know what could possibly be wrong with it.
Make sure all the pulleys the belt attaches to are spinning properly, if one is stuck or not spinning fast enough that will easily generate enough friction to melt the belt each time you replace it. Might need to replace other parts, or clean out more than just the brushes.
Jun 15, 2011 | Vacuums
Bought the iron with no instruction manual - don't know how to replace the anti-scale cartridge
Yes, since you did not mention any brand name or model, may I suggest that you visit again the store with your official receipt of purchase and your iron unit. Please demand a user's manual for it's important while your using the unit.
Jun 14, 2011 | Vacuums
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
How do I find the model number on my sunbeam mixer? I need new mixing blades
Some Sunbeam Mixers don't have a model number stamped on them. However, the service number located on the mixer functions basically as a model number when it comes to replacing parts. Hope this helps.
May 06, 2011 | Vacuums
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
Vacuums Logo
207 people viewed this question
Top Black & Decker Vacuums Experts
Lonnie Arks
stargajzer
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
