My screen keep flickering every 2 seconds. However laptop still can function as per normal. My laptop is LG brand, R405.How can I solve it? Or should i just spend my money to get a new one?
Posted by tohqijia91 on
Archaeology
    President:
  • 662 Answers
Your #1 suspect: LCD inverter, a circuit which supplies white light to the screen.
Step 1 (this is a workaround only)
Attach a regular CRT to the monitor port on the back of your system. You'll be able to use
the computer as before using the CRT as your display rather than the system LCD display.
Reasons to do this sooner rather than later:
(a) flickering with a frequency of 2 seconds is likely to cause headache.
(b) your LCD inverter is about to die.
Step 2.
Use your computer software (you didn't mention what OS you're running), hunt up any/all
vendor-supplied video diagnostics for your system, meaning any diags that run at any of three
levels: (1) BIOS (just above hardware level), (2) MSDOS, (3) MSwindows. The diag most likely
to help will be a BIOS video diag - though its possible that all video diagnostics may pass
without detecting an impending LCD inverter failure.
Step 3: Download the manual for your motherboard & computer system (they're probably from
different companies, with different web sites - you didn't mention the make/model/BIOS version of your motherboard, on your LG R405 computer). I went to http://www.lg.com
but couldn't find any laptops manufactured by LG - they're heavy into cellular telephony, though.
Posted on May 13, 2011
Lg r405 do not start when press on ac adapter works with 18.5V
Check AC Adapter for voltage output using multi-meter. If Adapter is GOOD, remove battery and try again. Does fan run? Does screen show Flash Screen? Please advise in detail.
Aug 21, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
How can i access to my LG laptop's Bois setup
when you start up laptop look at bottom of screen it should tell you what to press to enter bios, you will have to be quick because it doesn't stay on long. If this fails try F1 or F2 or delete after start up.(just keep pressing the key after you turn it on)
Jan 15, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
I have a brand new Presario Cq71 laptop which has once frozen altogether forcing me to do a hard reboot, and more recently the screen went black then almost immediately returned with an error message which...
here is the link to download the most recent graphics driver; select from the list your operating system, then select the graphics driver; the monitor will flicker for a second or two then should keep working normally
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3795238&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Aug 13, 2010 | Compaq Presario CQ50-215NR Notebook
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
I canot find drivers for LG Laptop (RD405/A.CD3282)
R405 and RD405 is same thing ok i am providing u with a link just go and download the software drivers whatever u like
http://www.notebook-driver.com/lg/lg-r405-ard405-a-express-notebook-windows-vista-drivers/
Direct LG US link for drivers or try www.lge.com for ur area
http://us.lgservice.com/index_b2c.jsp
pls vote me if i helped u
Feb 24, 2009 | LG X-Note LM50 Notebook
Computers & Internet Logo
184 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
