Master
- Posted on May 13, 2011
Re: My microphone is not working. What do I do? Trying to...
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
- Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
- Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
- Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
If it's disabled then you need to install your audio driver's again.
- Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
- Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
- To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.
- After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.
- After you select ok , then you need to select microphone from the recording options to activate recording via yoMy microphone is not working. - sajjad4help_7.gifg src="/uploads/images/sajjad4help_7.gif" alt="sajjad4help_7.gif" class="h_mi" />
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
