Question about Panasonic KX-TG2632PK 2.4 GHz FHSS GigaRange® Dual-Handset Cordless Phone System with Digital Answer
KX-TG9334GT I bought the 6.0 digital phone and am trying to find a place where I can purchase 2 more "expandable" phones... without the main base. This set came with 4 phones, but I need six, and from the description of the phone ad, this set can host up to six. How and/or where can I purchase the other two? I can return this product to the merchant I bought it from, but... I like Panasonic... I live in Kemptville, Ontario, Canada... K0G 1J0 [email protected] Thank you for any assistance you can provide.
Posted by PMS1 on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Panasonic Phone KX-TG2432
I have the same probloem with a KX-TG 5672. I am going to call 1 800 2111 7262 on Monday and ask for technical support. If you get a solution, pls notify me.
Posted on Jan 26, 2008
Anonymous
  • 4 Answers
SOURCE: Panasonic Kx-t7456 digital super hybrid system time setting question!
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
Anonymous
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
Anonymous
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Posted on Dec 22, 2008
Anonymous
SOURCE: Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Posted on Mar 23, 2009
Registration of phone to main phone
The come pre-registered to the Base Unit.
If for some reason it has not been registered base unit consult page 26... Of your OWNERS Manual The owners manual describes invoking code 130 .
if you not have your users/owners manual you can get a copy online... (see url, below).
http://ep.yimg.com/ty/cdn/yhst-86993463860622/KX-TGC212S.pdf#_ga=1.158670974.574155064.1461252188
Apr 21, 2016 | Panasonic NEW Expandable Digital Phone...
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
I bought 2 sets of the uniden DECT 1480-3. I want 6 handsets to work with one base. How do I add 3 handsets to a base that already has 3 handsets?
Jill,
The only logical way is to get the additional handsets to communicate with the base. And to do that you must set them to the frequency of the base. You Use guide will tell you how to set the frequency n the handsets to talk to the base. They way you set the original ones.
BUT, I doubt if this will work. Why? Because if that was the case if you and I had the same company phones, then I would stand outside your home and set the same frequency on my handset and misuse your phone. A great security risk in today's world. But there is no harm trying it out. Just set the same frequency on the additional ones as the base. If it works, then you will have that many more intercoms too. And do let me know if it works.
Apr 11, 2011 | Uniden Additional Handsets - DCT640 Phone
One handset on my uniden dxa13288-2 does not work. The battery is charged and good (swapped with other unit). When placed in masterbase, base led flashes, indicating good data marriage on both. The good...
The handset for this unit registers automatically to the base. The main base sync with the handset but it does not respond. The handset that is not responding has a problem and should to be replaced. You can pick one up on eBay for a few bucks.
Jun 02, 2017 | Uniden 2.4GHz Digital Answering System...
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Purchased New Uniden cordless phone wih and answering machine. This item works properly. Purchased the matching space phones Uniden DXI 8560-2. The instructions on the back of the phone simply says to set...
YOUR PHONES ARE NOT EXPANDABLE TO MORE THAN WHAT THEY COME WITH, ONLY BECAUSE YOU WANT THEM TO WORK TOGETHER DOESNT MEAN THAT THEY WILL WORK TOGETHER...
Jul 19, 2009 | Uniden Cordless Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Expandable handsets lose activation:
USer manual requires,
full charge 16 hours for expandable handsets, then place in cradle ~20 seconds until 'ready' is displayed on the screen.
If power is lost the handset may have to be re-registered.
if the units are not fully charged when you register them the registration may be lost, can only suggest reversing the order, by fully charging the device then registering to see if the registration holds
Nov 12, 2006 | GE 25931EE1 Phone
Panasonic KX-TG2632PK 2.4 GHz FHSS GigaRange® Dual-Handset Cordless Phone System with Digital Answer Logo
50 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
