Please check Charging solenoid (S3) in Solenoid manifold block, it may need to change solenoid coil or Rebuild. If charging solenoid is OK, then problem can be SCALE or MAIN CIRCUIT BOARD. See if the machine display show default charging weight 90 kg/lbs when you active CHARGE mode. If not then calibrate scale. But if default charging weight is shown then replace MAIN CIRCUIT BOARD. See attached picture to find solenoids. I wish this will help you to solve the problem. If so please vote for it for further assistance. Best of luck!
Looking for the Robinair ACR 2000 calibration procedure, please contact me at [email protected]
How calebrition robinair macine
It's sound to me you need to Replace the Compressor. Check spin-on
filter (press MENU button on the control board & then keep pressing up or
down arrow key till appear "FILTER CAPACITY", then press ENTER key). If
the filter already recover 68KG/150LBS refrigerant since last filter change. Then
you have to replace spin-on filter immediately! Over filter weight is the main cause of
compressor damage
But if you want to make sure
yourself, please do the following: Press recover & fix a vacuum gauge on
your machine Compressor suction port & monitor the gauge is going up
to13"HG suction, if not then you need to replace the compressor.
I wish this will help you to solve the problem. If so, don't forget to vote for
it. Good luck!
