Question about Haier BC112G Wine Cooler
Making noise - Haier BC112G Wine Cooler
Posted by pegpete0084 on
dale butzin
    New Friend:
  • 36 Answers
Not to many moving parts on that wine cooler more then likley it is the compressor making the noise. check your warranty to see if the compressor is covered
Posted on May 13, 2011
Can a cam shaft synchronizer make a rattling noise ?They usually make a chirping noise when they go bad. I was told by a Ford tech that it was the synchronizer making the noise. This is a 01 Windstar.
they make all sort of noises not just chirp they can make grinding,clanking,whirling ,clunking etc really no set noise because if broken verses worn will give different noise
Aug 14, 2016 | Ford Cars & Trucks
Can cv joints cause noise when braking
No really because there is pressure both ways keeping them from making noise. Usually they make noise when turning(clicking type noise) or them hum at higher speeds. This also sounds like bearing noise. The way to tell the difference is bearing noise will get loader or softer when your are making turns. Axles will have a consistent noise to them. Now bearings will make a noise when stopping.
Mar 01, 2015 | Cars & Trucks
Grinding noise when its in nuetral with engine running
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make grinding noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Isuzu Pickup
I have a 02 passat when I start If up it sound like a truck. What do you think it can be. Its not turbo it just started doing it
There is N-number of possibilities for the car to make loud truck noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
My eclipse spyder 03 started making that noise like a week ago on the drivers side ? Anybody help plz!!!!
There is N-number of possibilities for the car to make whining noise or any other kind of noise.
These will help.
Thanks.
My 2004 t&c 3.8 is making a weird sound like a
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
These will help.
Thanks.
Thud in trunk at take off
There is N-number of possibilities for the car to make thud noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | 2010 Toyota Camry
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Dryer makes clicking noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
w56w
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Haier BC112G Wine Cooler Logo
200 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Haier Furniture Expert? Answer questions, earn points and help others
