On most Caloric stoves, the F7 error indicates a short detected at the key pad or a stuck key. Try unplugging the stove (or turning it off at your circuit breaker) for 30 seconds or longer. Check that the glass touch panel is correctly seated over the membrane with the switches. The usual recommendation is to replace the touch pad. (Sometimes, the problem will be with the wiring or the ERC (clock) that reads the touch pad signals.)
What model stove do you have? If you add a comment with the model number, I may be able to point you towards the correct parts. If the stove is still under warranty, contact the manufacturer.
The F2 E0 error means that the control board believes that a key on the touch pad has been held down for an extended period or has shorted. Assuming that no one is holding the buttons, try pressing Cancel to clear the error. If the error recurs promptly, check the wiring harness between the key pad and the control board to make sure that the wires are tightly connected. If the problem continues, you probably need to replace the touch pad (key pad) assembly. On some Whirlpool models, the keypad and the central control board are sold as a single assembly. In that case, you'll need to replace the entire unit.
If you add a comment with the model number of your stove, I may be able to give you the part number for the keypad. I hope this helps.
f1 indicates a faulty erc electronic range control or a stuck key pad. First check the keypad by pressing each button one at a time. You should hear a click and feel it fully retract. If it does not replace the keypad. If the keypad is working properly the erc will need to be replaced. Here is a link that should help with this problem http://appliancehelponline.com/ovenerc.html
hello there Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault CodesFailure CodeFault Code DescriptionSolution
F0
Function key stuck
Replace touch pad or if touch pad is part of the clock, replace the clock
(ERC).
F1
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
Refer to F1 test at the top of this page for more information.
F2
Oven temperature too hot
Replace relay board, if present, or oven temperature sensor (RTD). Check
sensor harness.
F3
or
F4
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
F7
Function key shorted or stuck
(ERC).
F8
Analog / Digital problem
F9
Door latch
Check door latch components.
Find Parts
HI. This code is referring to a failed function key(s). These key are located on the control board. Replace the touch pad or if touch pad is part of the clock(main control board), replace the clock
(ERC).
F7 Means a stuck key on key pad or a short to the control panel the control and key pad has to be gotten to threw the back of the stove make sure to unplug the stove first ...
Shorted key
panel membrane switch; Check Electronic Range Control (ERC)
Determine if problem
is with the Key Panel or Control by: 1. Pushing CLEAR/OFF pad. 2. Disconnecting Ribbon Cable from control and waiting
at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
F0
Function key stuck
(ERC).
F1
F2
sensor harness.
F3
or
F4
F5
F7
(ERC).
F8
F9
Door latch
F7
Function key shorted or stuck button
Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
F7
Shorted key sensed for 32 seconds
1. Membrane shorted, or, 2. Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back. Unplug range before doing so. Once touch pad is disconnected, plug range back in and see if code shows. Wait a few minutes. If no code then replace touch pad. If code does come on while touch pad is disconnected then replace main control. If touch pad and main control are all one part then replace the whole control. Doubt if you would have any luck trying to unstick the bad button as stated above.
