Question about Lite On Computers & Internet
HI I HAVE SEVERAL LITEON POWER SUPPLYS MODEL NO. PA-1201-1 THAT HAVE WENT DEAD. IT SEEM THAT THIS POWER SUPPLY FAILS ALOT. I WAS WONDERING IF THERE WAS SOME WAY I COULD FIX THE UNITS THAT I HAVE. DO YOU HAVE SCHEMATICS ON THIS MODEL. OR ANY KNOWLEDGE ABOUT THE ROOT CAUSE OF FAILURE. THANK YOU JOHN BECK
Posted by jbeck550 on
  • Frank Jan 17, 2012
    There is a company based in the UK called Avanti Power Repairs Ltd who repair these things at a good price.
  • Todd
    Todd Apr 12, 2016
    John: Did you ever find a solution to your LITEON PA-1201-1 power supply problem? I also have one that I would like to fix or have repaired. I'd love to know what you learned in the mean time. Thanks!
Art Ellison
  • 2,229 Answers
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
Posted on May 12, 2011
Name of wire based on color coding wire
Special (only on the ATX conector)
-Green is PSon(put a wire between green and black to turn the power on)
-Gray is PWRGOOD
-White is -5V(optional)
-Blue is -12V
-Purple is 5VSB(Always on when the PSU is plugged on)
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
-Black is Ground (0V)
Dec 20, 2012 | Lite On LiteOn 204Watt PA-4022-6B Power...
[email protected] not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
Mar 03, 2010 | Computers & Internet
Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Dec 13, 2009 | Computers & Internet
Where can I get a 12v 4amp power supply
look on amazon web site if you have old power supply you can use model number on it
if not try the model number on the appliance
hope this helps MERRY CHRISTMAS
Dec 04, 2009 | Audiovox AVT-1475 13" TV
Cable/Transformer for Quantum Server 1000
I've got the same Snap Server 1000 and lost the supply some time ago - I found a LiteOn monitor supply model PA-1400-02 does the trick and fits exactly.
Spec is 3.33A 12Volts DC out, positive inner, negative outer.
Hope that helps.
Jan 19, 2009 | Quantum Snap Server 1000 (5325301081) 10...
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
