Question about Craftsman 2.0 amp Rotary Tool Kit
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to make sure there was no pressure and it's acting like one solid piece between the collet/collet nut and bit. Ideas?
Posted by sandiclaws on
EugenesDIYDen
    Guru:
  • 479 Answers
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
Posted on May 12, 2011
Change the bit on the model RE 175
Hello there
Seems like the RE175 manual is not longer available at Ryobi.
This is from the manual for the RE180 which MUST be similar to the re175. Manual download here https://manuals.ttigroupna.com/system/files/5849/original/RE180PL1_448_trilingual_05.pdf?2014
From page 7 ....To remove the bit:
Place the wrench provided through front of router base
onto collet nut and turn counterclockwise to loosen.
Loosen the collet nut and remove the bit.
Release the spindle lock
Sep 24, 2014 | Computers & Internet
How do I change bits....have not used router in years
Most routers have a "Pin" that can be depressed to lock the router spindle. But first, rotate the spindle to match a small hole in the spindle with the pin. With the spindle locked in place, use a wrench (routers often come with this) to loosen the "collet" which holds the router bit. The collet nut will turn counterclockwise when loosening the nut, when looking directly at the bottom end of the router bit, i.e. when looking down at the router when the router itself is up side down.
To install a bit, reverse the process above. Do not overtighten. About a on-eighth turn past handtight will suffice. The collet or the threaded end of the spindle can be stripped out.
Hope this helps.
Apr 27, 2011 | Garden
Back in December 2009, I wrote asking why my Freud FT2000 router wouldn't release the router bit when the collet nut was loosened. "allstarbob" wrote and said to sandpaper the collet. That didn't make...
Thanks for the follow up....
I'm glad your problem was resolved in the end.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 10, 2010 | Freud FT2000E 3 Router
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
How to use the collet wrench
There should be a spindle lock near the collet end of the tool. Engage it and then put the wrench on the collet nut and loosen the nut. If the bit is stuck just tap the end of it slightly to loosen it and it should come out. Reverse this process to install a new bit...hope this helps you...Jeepfxr
Oct 18, 2009 | Craftsman Tools & Hardware - Others
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
My Dremel lock nut won't budge. My collet is stuck! How can I loosen the bit?
You'll need to use either the built in shaft lock to hold the collet in a fixed position, or use a pair of slip joint pliers to hold the shaft of the bit, while you use the wrench to loosen the collet. Slow and steady should get it loose. Another option is use some penetrating oil sprayed lightly onto the back of the collet to help loosen it from the shaft etc.
Jul 17, 2009 | Dremel Variable - Speed Multipro Rotary...
How do you fit 6mm collet cone on new produce
You have, I presume, already locked the spindle and loosened the collet nut with the wrench, have you not?
Once the nut is loose, you should be able to remove it by spinning it off the threads by hand. Then insert the 6 mm collet cone into the collet,
carefully thread the collet nut back onto the collet, and tighten it with the bit in place.
Sometimes bits are a snug fit, especially into a new collet. If you have some fin sandpaper you can gently chamfer the very end of the bit where you first insert it into the collet, and this may help to insert it. If you have to, push a bit.
I have noticed that some companies tend to mill the shafts of their bits a little too close to the exact tolerance, or even oversize them slightly, and this can cause frustration when inserting their bits. In exceptional circumstances, I have resorted to polishing a couple of small bit shafts with very fine (600 grit or so) emory cloth, just to allow the bit to enter the collet. I would not recommend this with a new router collet, unless you have checked the bit with a micrometer and it is oversize. Odds are you just need to break things in a little.
The force need not be brutish, but you may need to use some force, yes.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 29, 2008 | Makita 3612C Router
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Craftsman 2.0 amp Rotary Tool Kit Logo
594 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
Sheldon Dedek
efs_perpends
efs_perpends
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
