If your Delsey combo lock won't lock, there are a few things you can try to troubleshoot the issue:
Check the battery: Make sure the battery in the lock is not dead. If the battery is low, replace it with a new one.
Check the lock's alignment: Make sure that the lock is properly aligned with the suitcase zipper. Sometimes the lock may be slightly off-center, which can prevent it from locking properly.
Check the lock's mechanism: Make sure that the lock's mechanism is not jammed or damaged. If it is, it may need to be repaired or replaced.
Check the lock's code: Make sure you have entered the correct code for the lock. If you have forgotten the code, you may need to reset the lock or contact the manufacturer for assistance.
Clean the lock: Sometimes dirt and debris can accumulate in the lock mechanism, preventing it from functioning properly. Clean the lock with a soft cloth and mild soap.
Check the suitcase: Make sure the suitcase is not damaged in any way that can prevent the lock from closing properly.
If none of these solutions work, it may be best to contact Delsey customer service for further assistance. They may be able to provide additional troubleshooting steps or may suggest to get the lock serviced.
Your adjustable TSA combination lock as delivered can be opened with the combination 0-0-0. To change the combination: 1. Open the lock by entering the factory code 0-0-0.
2. With a pencil or something pointed, press firmly on the Reset A button until you hear a click. Keep it pressed down.
3. Enter your secret code (for example 8-8-8) by turning the wheels.
4. Push button B so that button A goes back to its original position.
Your code is now registered. Write it down in a safe place so that you can go back to it if you forget it. If you want to change the combination, repeat steps 2-4.
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
I need a new handle for my Delsey Club Suitcase
