Question about Lexmark X5470 All-In-One InkJet Printer
Good morning, i was printing and the printer shut
Good morning, i was printing and the printer shut off after the last page printed and will not turn back on; also the power pack has power
  • Official Brand Answer
  • 3,344 Answers
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
Posted on May 20, 2011
6ya staff
SOURCE:
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
My printer Epson t13 has a general error it says ''delete all print jobs and turn off the printer and remove any foreign objects from inside the printer. after a few minutes turn the printer back on. But...
Good morning to you!
It might be worth trying to go to the "print page" on your computer and remove the print queue, then there is nothing waiting to be printed. Then disconnect the printer for 30 sec. or so and restart your computer. Give it a try, good luck,
kolbrun
May 26, 2014 | Office Equipment & Supplies
Yesterday I printed a page and could not print second page, so i shut everything down, this morning i turned on my computer and the printer started up & started printing & ran till out of paper....
Disconnect the printer power plug from the wall for 2 mins and plug it back in and turn the printer on and turn on your PC and see if that helps. The printer has a memory which stores information you may have sent to the printer. If you kept hitting the print button then it may have saved all those print commands in memory and it is printing that out. That is what happens most of the time at my office. So you need to erase the memory by turning off the printer from the wall. Hope this helps
Aug 14, 2010 | HP Office Equipment & Supplies
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Hp Photosmart 3310
wow..try a test page to see if the printer is happy on it's own.
Aug 19, 2008 | HP Photosmart 3310 Printer
Printer problem
Usually it print blank because of wrong page selection. Make sure you put the page you want to print.
Mar 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Unwanted repeat printing
There are 2 possible reasons:
  1. The last printjob remains in the COMPUTER'S memory
  2. The last prinjob remains in the PRINTERS memory
You can easy find out in witch case you are by turnig on the printer in the morning before turning on the PC.
If the page from yesterday do not print without the PC on then try reinstalling the printer (after uninstalling it - or delete it from Control Panel - Printer and Faxes). Pay attention before shutting off the PC if there are running jobs in the printer. (doubleclick the printers icon in Control Pannel - Printer and Faxes). If they are, try to delete them before shutting the pc off.
If the page do print evan without the PC turned on, than it's in the firmware and i have to admitt that i dont know exactly what the solution could be, but let me know and i'll search again.
Jan 24, 2008 | Minolta PagePro 1300W Laser Printer
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
189 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
