Is ice maker not working, do you mean it has no power at all.Then its faulty control board.But if there is power to ice maker and its not making ice then its not board but it can be faulty valve.---------
Ice maker stopped making
ice. For this problem you have check few things. First thing, is the water
filling in the ice maker chamber and then ice maker not making ice? Or, the
water is not filling in the ice maker chamber so it's not making ice. If the
water is not filling in the ice maker chamber then it's clear that ice is not
getting made due to no water in the chamber. For no water filling, the problem
is either water supply valve turned off so water is not filling. Turn on the
water supply and it will fill. But if the water supply is turned on then the
other possibility is ice blockage in the water fill tube. There is a tube from
which the water runs and enters the ice maker chamber. If this tube is blocked
then water will not enter the chamber. The tube needs to be defrosted, by using
hair dryer. This procedure melts the ice collected in
the tube and water starts running again. But if water fill
tube is completely clear and no ice blockage or any other blockage. Then other
possibility is water valve at the back of ice maker unit. This water valve is
for letting the water in the ice maker. The water valve open only for
7 seconds and in this time the water fills in the ice maker chamber and then
water valve closes and the same procedure runs again in the next
water filling cycle.------- For your information I will mention that there are
two valves. One is the main valve the back of the fridge section. This main
valve lets the water enter the refrigerator and other valve is at the back
of ice-maker section. This other valve lets the water to enter the
ice maker. In most of the cases the fault is water valve at the back of ice
maker section. ------------- The other above possibilities which I gave you is
water not filling in ice-maker chamber so it's not making ice. But
now consider that water is filling in ice maker chamber but it's
still not making ice. Then the problem is ice maker unit itself. This unit is
controlled by main board. But in most cases if water is filling the ice maker
but it's not making ice then its faulty ice maker unit. So see if the problem
is water not entering the ice maker then the water fill tube is frosted by ice
or the water valve at the back of ice maker is faulty. Replace the valve.
------------ You can get required
parts from sears part direct online site or from repairclinic.com site. -------- This will help. Thanks.
Helpmech.
Posted on May 12, 2011
SOURCE: ice maker stopped working
pull the front cover off of the icemaker and see if the drive gear is broken (there are 2 tabs in the center of the gear make sure these arent twisted or broken as well) if so replace the module on the fron of the icemaker. if that checks fine check for frozen fill line..
Posted on Dec 16, 2007
SOURCE: maytag ice2o won't make ice
theharrisont, You state that...." ice maker stopped working after it flooded our kitchen floor." The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced. Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly). The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date. Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem. You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice. Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker. Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed. A hair dryer is a quick way to achieve this. Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker. Note: Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice.
This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Posted on Feb 07, 2009
SOURCE: Ice maker has stopped working
There are a number of things that can go wrong, the solenoid valve for the icemaker could be bad, the icemaker module could be bad, or if it has a blinking red light on the right side of the freezer section, that electronic sensor could be defective, If you don't have a multi meter to check these problems, you should really call a certified tech.
Posted on Jan 23, 2009
SOURCE: ice maker stopped working. In door water
Hi TBurl,
Yeah... classic sign of a failed water valve. You need a new one. The part number is D7742204 (<---plug that into a search engine or call a local appliance parts outfit to get one).
Easy to replace... Just pull the fridge out, UNPLUG IT FROM THE WALL, turn the water valve off at the wall, remove the water line from the fridge valve, then remove the 2 screws mounting the valve bracket to the base of the fridge. All you have to do now is remove the electrical connectors and the tubing from the old valve and place them on the new one (making sure to get the wires right, OK?). Now just mount the new valve, reconnect the water, turn the water on and plug it in!
EASY! All in all about a 20 min. job. There ya go! Your fixed. Don't forget to rate this solution, OK? My self-esteem is depending on you. :P
SG
Posted on Jun 04, 2009
SOURCE: ICE MAKER STOP WORKING
the water comes in from the wall and then it run to a solenoid then to the ice machine.the timer on the ice box tells the solenoid when to open and close,
Posted on Jun 17, 2009
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
directly.
in refrigerator?
refrigerator?
other ice maker related issues and solutions:---
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
May 20, 2010 | LG LRSC26980 Refrigerator
Oct 08, 2009 | KitchenAid KSCS25FKSS Side by Side...
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Dec 10, 2008 | GE J Series 18.2 cu. ft. Top Freezer...
Feb 11, 2019 | Whirlpool Refrigerators
Jan 29, 2019 | Whirlpool Refrigerators
2,648 people viewed this question
