Resetting
a Dell Latitude to the factory settings allows the user to restore the
Dell Latitude to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Latitude laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Latitude laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Latitude reset process...
This
process will erase all your previous changes that have been made to the
Dell Latitude laptop and reset the configuration settings to factory
setting.
Feel free to get technical assistance for all type of Dell laptops(Vostro, Latitude,Inspiron...etc..) at http://www.vtechsquad.com/dell-support/
Restart the computer and as it is restarting Press F11 and follow the on screen instructions. If this does not work then one, change is necessary which is, as the computer is restarting ,Press F11 and CTRL together and follow the on screen instructions. Some times the key combination is different so try F10 if the above does not work. good luck
SOURCE: how do i restore my
Turn the computer on, after you see the "Dell" logo, press and hold Ctrl then press F11, then release them both at the same time. If that dosen't work after the dell logo contunilusly press Ctrl and F11 repeatly at the same time and the dell recovery partition wizard should show up. Source(s): Dell service Repair Expert
SOURCE: how do i restore my dell latitude d410 laptop if i
That is difficult if it is asking for that. Normally you can start the laptop and right after you see the Dell splash screen press the F11. That should bring up the restore menu by passing any security you have setup. From there you can select to restore the computer to factory settings. If you have the restore DVD's then you can put the first one in the DVD drive and boot the computer and it should start from the DVD instead of the hard drive. Now, these will all work if you haven't setup security in BIOS requiring an Admin password. If you setup the BIOS passwords then you are going to have to try and reset the BIOS. Not impossible but a little harder. Remove the power cord, remove the battery and open the covers on the bottom of the computer. Under one of those you should see a small battery, remove that battery and keep it out for 60 seconds. put everything back in place and restart the computer and the BIOS should reset.
