Do you mean that you want to save the letter as a PDF file? That is the default file type of Adobe Acrobat. Did you install the Smart Thru software? You should double-click the icon for the program and then select Scan to File. Set the file type to PDF when you save the scan. Alternatively, add Adobe application into Printer Setting Utilities. Make the Adobe application the default.
Third party software is available to do this as well if you do not want to use the Smart Thru software. Paperport is the software that I use most.
Support for the Samsung SCX-4300 is available here: http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Download Centre tab for manuals, drivers and software.
I hope this helps.
