HP Pavilion m7570n (EX331AA) PC Desktop Logo
Question about HP Pavilion m7570n (EX331AA) PC Desktop
I have a HP m7570n. How do I use a flat screen tv as a monitor
Posted by rwalsh2112 on
  • HP Master
  • 6,562 Answers
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
Posted on May 12, 2011
Steve Macqueen
    New Friend:
  • 53 Answers
The video out on the back of your computer case is most likely a "VGA" you can get a "VGA-HDMI" adapter, and run a HDMI cable from your case to your tv.
I have a HP envy750-414 hook up to a flat screen tv how do I adjust the resolution I have tried everything do I have to get an HP monitor.
The resolution is controlled by your computer the same way you would control the resolution if you were connected to a monitor. The problem may be the TV, you say it is a flat screen but you don't give any more details. How many inches? Is it 720p, 1080p or is it a HDTV. The 720 will give you the worst picture and the HDTV will give you 1920X1080 resolution. What connection did you use? A VGA connection will not be as clear as HDMI.
HP Pavilion Media Center TV m7570n Desktop and Vista home networking problem
this could be as a result of the ip address been the same or the systems not seeing each other
Cannot get to be a monitor for my pc
check your resolution settings also set the hertz properly, it should be working!
1helpful
HP Pavilion M7570N found in a storage unit sale, how old is this and is worth anything
Hi vollybill....
Your M7570N date is: 08-Jun-2006, that is when the machine was introduced.
It is a "Media Center" desktop, so it is a better desktop of its day. It also has a larger hard drive.
I will include a webpage so you can check out the specs on the computer..as far as price, it is anybodys guess to how much a five year old computer is worth...
Please take time to rate me
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00705316&cc=us&dlc=en&lang=en&lc=en&product=3185132
I lost 90% video function on my HP m7570n desktop computer. The monitor pictures are blurry and difficult to make out. I understand that the video-card is integrated with the motherboard. other than the...
I would check the driver first then for a virus and if all else fails, select a VGA board of your choice, (and one that will fit), then install it.
Go to your BIOS and turn off the onboard VGA then load the drivers for the new board.
Hope that helps.
My desktop wont turn on it starts up when i plug
Either the tiny plug on the mobo has come off / faulty switch / faulty mobo.
1helpful
Hp pavilion m7570n my little sister was playing her online game to the site for at least an hour and all of a sudden it shut down automatically and i turned it on.but the power wont work anymore as in dead
switch out the power supply and it should fix the problem. also buy a can of air and blow it out before putting the new power supply in.
here is a decent power supply. just copy and paste the link.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171046
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
