Question about Sanyo DP50747 50 in. Plasma TV
We were watching the tv and it turned off and now it won't turn back on. we have never had any problems with it before.is it worth gettinh fixed.is there a rest button?
Posted by lhscraig on
Chi Chu
  • Sanyo Master
  • 8,457 Answers
Tv now turn on have no power to the tv at all or the tv power LED light on the tv just blinks.Tries tv unplug,replug the tv back like about an hour,that the resetting tv back to the factory setting.The tv should working again now.If not the tv power supply board it is dead that the board where the power a/c cord plug into it,tv must be repair by replacing components parts or the tv whole power supply board.The tv shop should cost u like about half of the price of a new tv.
Posted on May 12, 2011
TV won't come back after pushing wrong button on remote.
Try unplugging the TV.. After you plug it back in it may be OK. I had a similar problem were I could not turn on the TV (JVC). The owners manual specified in the troubleshooting section to unplug for 1/2 hour. I left it unplugged overnight and the next day plugged it in and it was fine.
May 21, 2013 | Televison & Video
My tv suddenly turned off and won't turn on
Check its main power supply regulator board for fault.
Mar 09, 2013 | Televison & Video
Problem with Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television. Does this indicate that the lamp is burned out?
if the lamp indicator is blinking and won't turn on which means you will need to replace the lamp.if you don't have an idea how to replace just leave it to the tv technician to fix your tv.
Sep 17, 2012 | Televison & Video
ILO TV won't turn on
You will need to have the set professionally diagnosed. You could either have a faulty power supply or main board. You could also try unplugging the set for a bit and plugging it back in. I doubt it will solve your problem but it is worth a try.
Sep 03, 2012 | iLO Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My tv turned off and won't turn back on. There is an orange light still on
It sounds like the power supply board has failed. On TVs that are this age this is a very common problem. Contact the extended warranty company and have them send a tech out.
Jul 16, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
My tv won't turn on
If the screen is damaged/shattered you are done. Not worth the cost of the part or labor.
If something else use the "make a comment button" on this page to let me know.
Mar 26, 2012 | Emerson LC320EM9 32 in. LCD HDTV
My ws-55908 just turned off the other day and does not turn back on.
the main power supply has gone out it may not be worth the 4to5 hundred to repair it
Jun 21, 2008 | Mitsubishi WS-55908 55" Rear Projection...
Lost remote
lost remote, can not switch imput
Nov 01, 2007 | Televison & Video
Sanyo DP50747 50 in. Plasma TV Logo
Top Sanyo Televison & Video Experts
Mike
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
