Question about Andis AG 2 Hair Trimmer
How to put together the blade - Andis AG 2 Hair Trimmer
Posted by dalba281 on
Mannys Sharpening
  • 38 Answers
How to put together the blade - askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Slide Socket back as shown in picture
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the SpringHow to put together the blade - askmanny_6.jpg src="/uploads/images/askmanny_5.jpg" alt="askmanny_5.jpg" class="h_mi" />
Make surHow to put together the blade - askmanny_8.jpgis on like picture above, Now place Socket & Spring aside askmanny_6.jpg
THow to put together the blade - askmanny_9.jpgPlace comb blade as picture above askmanny_8.jpgHow to put together the blade - askmanny_12.jpge blade like this Finger on top and Thumb on the bottom
Turn blade over like this while still holding the blade together askmanny_11.jpg
Place screw as shown askmanny_12.jpg Screw in the screw don't tighten leave loose. askmanny_13.jpg
Now that you have the 2 screw in and not tight place the blade like this You nHow to put together the blade - askmanny_15.jpg blade with one hand and with your Philips screw driver tap the cutHow to put together the blade - askmanny_16.jpglightly until the cutter teeth are 2/32 back from the comb blade.
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
Posted on May 12, 2011
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Nov 10, 2011 | Wahl 9854400 Hair Trimmer
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Can't put blades back
mcdevito75 here, Bring the shaver to any drugstore in your area they should be able to help out.
Jun 24, 2010 | Igia AT7352
Took oster blades apart and now don't know how to put them togeth
First thing about Detachable clipper blade are Tension and straightness, You need a special tool to set the tension on your blade and the spec's on how much tension, plus you need to set the straightness of the tension spring. With out these tools your blade will not cut, even if some body sharpens the blade and do not set the tension correctly and straightness. You need to send it to a professional sharpening company, mannyssharpening.com has a mail order service he charges $8.00 to sharpen set to factory spec's and this price includes return shipping, they are fast in service.
Mar 26, 2010 | Oster 76076-010 Hair Trimmer
How do I put my shaver back together after I replaced the blades?
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Mar 12, 2009 | Health & Beauty
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Put it back together
Purchase the DVD on "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Jan 15, 2008 | Andis Outliner II Hair Trimmer
Andis AG 2 Hair Trimmer Logo
2,422 people viewed this question
Top Andis Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Marvin
Marvin
NOEL
NOEL
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
