A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
If connection is still not established, try to print the network settings page to determine if your printer is still registered in your wireless network.
1. Press Setup () on the printer operator panel.
2. Press the right or left arrow button until Network Setup is displayed, and then press().
3. Press at Print Setup Page.
4. when prompted to Load PapAfter the power went out - pattlnk_632008_2052-x4650ok.jpg>Press . The network settings page will now print.
Check the SSID and the IP address on the settings page. If info shows that your printer is no longer registered, you may need to reset the wireless network settings of the printer.
Follow steps 1 & 2 above,
3. Press the right or left arrow button unAfter the power went out - pattlnk_632008_2052-x4650ok.jpgfaults is displayed, and then press .After the power went out - pattlnk_632008_2052-x4650ok.jpge right or left arrow button to display Yes, and then press .
5. Observe the message"Clearing Wireless Settings". The WiFi light will momentarily turn off then lights up solid orange. You can now launch Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) to reconfigure your printer to connect to your network.
Sources: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs) & How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults.
