My radio needs to be reset. I have the code for the radio but when I switch it on it only says SAFE. can you please help me.
The Serl nr of the radio is: vwz4z3g1100046
The VIN nr of the car : AAVZZZ17Z7U018286
The code of the radio is 0133
As I said it only shows SAFE when I switch it on. Please please help.
Buks [email protected]
082 5783 174
If you made 2 errors, the radio will locks up. You could pull out the radio for several day, or months, but never will reset this hard SAFE.
The solution is easier than you are thinking; "Just turn on the radio, and turn on the switch key, but don't run the car. Leave ON the car switch and ON the radio for one hour".
After it, you will be able to use your unlock code. (Holding Mode+Scan until SAFE change to 1000... )
Remember... you have just 2 oportunities to enter the right code
hey. but my radio dosen have a ''mode'' THE SCAN its but mode no what to prees to remove the safehey. but my radio dosen have a ''mode'' THE SCAN its but mode no what to prees to remove the safe
You can't post conmments that contain an email address.
did you check manual if there is radio code card ?
if you do not have it, you two choices either visit dealer and they will be able to obtain correct code for your radio or try to contact Panasonic and find out their repair shop for automotive radios they will be able to reset for you they even might disable the safe mode so in case power loss you will not have to re-enter again
The sequence of programming for 1999 Volkswagen Passat radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. For example: we have the security code "5079". Then: 3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted. 4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted. 5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted. 6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. 3. By the #1 key you will set up the first safe code digit. 4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit. 6. By the #4 key you will set up the four-th safe code digit. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use! Please do rate my response. Thanks!
How to exit the 1998 VW Passat radio out of SAFE mode: IMPORTANT NOTE: You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer! The sequence of radio programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. 3. By the #1 key you will set up the first safe code digit. 4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit. 6. By the #4 key you will set up the four-th safe code digit. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer!For Audi Concert Radio the sequence of programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. 3. By the #1 key you will set up the first safe code digit. 4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit. 6. By the #4 key you will set up the four-th safe code digit. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
"2 safe" means that you have entered the wrong code twice. Leave the igniton switched on for about an hour and it will reset to - - - (three small lines) then you can enter the correct code. If you dont have the code you will need to speak to your vw dealer
Passat 97 need to re-enter code ( 4 ) digit, however it shows the number 2 on the on screen when the radio is turned on.
Help. I need to know the steps to reset. thanks
could you give me code for beetle vwz9z75135463
