Question about HP Color LaserJet 2600n Printer
How do I print legal size envelopes using 2600n laser jet printer?
Posted by info27639 on
Seeker5211
    Genius:
  • 1,089 Answers
Use the manual feed tray(tray 1).
Do one as a test to make sure that it is facing the correct way.
Posted on May 12, 2011
Can't get small envelopes to print correctly on hp laser jet pro MFP M127fw
Go to printer setting options and choose paper size and font size, according your size choose it. I share a more help full links.
Read More Help...
Scale document to fit on different paper sizes
Resize the page or paper
And HP Printer Support
Thanks,
Aug 27, 2014 | Office Equipment & Supplies
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
HP Laser Jet P2035 is not printing the "from address" on envelops and even the "to address" is not being printed on the right spot. The envelope size, tray and feed mechanism are...
The easy way to diagnose this is to put a regular piece of paper in and print the envelope on that to see where it is actually printing. This is likely a wrong envelop size selected in your software not a problem with the printer. It is only reproducing what it is told to. Also make sure that the paper options in the print driver reflect the correct settings for size of paper.
Mar 17, 2011 | HP LaserJet 1320 Printer
We want to purches a laser printer for printinhg legal size paper,which printer we use
Hello
You can any of HP laser Jet with your budget for legal size printing, all printer can print legal size printing, however there are some printers for quick reference.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
Dec 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Problem to print envelopes
u can change the size of the paper size , u can make that from the default settings o, u can get that by making right click at the printer in control panel --> printers --> right click the Properties , u must be the administrator user of that computer , or press shift + right click the choose Run as .
Jan 28, 2009 | HP Color LaserJet 2600n Printer
Printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
Dec 27, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
HP Color LaserJet 2600n Printer Logo
57 people viewed this question
Ekse
efs_perpends
efs_perpends
