Question about Frigidaire Affinity ATF6000F Front Load Washer
Need to print manual on how to use my washer Affinity model.
Posted by lrc_ministri on
Mainetech
  • 37 Answers
This is the first one I found, check your complete model number and make sure it matches, if not the others are available in the Frigidaire website.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134850600een.pdf
Let me know if this helps,
Thank you
Posted on May 11, 2011
Tip
Affinity Washer Factory Service Manual
Here is the link to the Factory Repair Manual for your Frigidaire Affinity ATF6000 - 7000 Series Washing Machine.
Frigidaire Affinity Washer Repair Manual
Thanks
on Jan 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
Where is the filter located on the affinity front load washer
Hi Kimberly,
I understand that you're trying to find out where the filter is on your affinity washer. You have to take the back of the washer off --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
http://www.frigidaire.com/manuals
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
When i turn on my frigidaire affinity front load washer it beeps and LOC comes on the screen it will not do any thing I have unplugged for a while it still says samething with the door open or closed ....
The control lock feature has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. There is a small padlock indicated in the middle of a line between the buttons that toggle the lock on and off. This feature prevents anyone from changing a wash program when in use or a child starting a cycle with the cat or another child in the washer.
The manual for most Frigidaire appliances are available here: http://www.frigidaire.com/manuals . Enter the model number and click Search. Frigidaire lists several models of the Affinity ATF7000E. The direct link to the operating instructions manual for the ATF7000ES0 is here: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134602700ef.pdf . In this manual, the control lock is described on page 2.
I hope this helps.
Oct 30, 2011 | Frigidaire Affinity ATF7000E Front Load...
E10 on my Frigidaire Affinity Front Load Washer
just go to fridge website support center and see what the code is or google Frigidaire code 10
Jan 22, 2011 | Frigidaire Washing Machines
Where is the filter located on a frigidaire Affinity washer ?
You have to take to back off the washer --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
Jul 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
Door lock doesn't release automatically; clothes still very wet
You need the Factory Repair Manual for your Affinity Washer. There is alot that can go wrong with these machines and you will need to run the washer through its diagnostics.
Here is a Link where you can Download the Affinity Washer Repair Manual
Thanks
Jan 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontl load washer and dryer manuel
The best thing for you to do is go to this link;
http://www.frigidaire.com/support/support.asp
and download new manuals and print them out. You will need them in the future. You will need both your model names and model #s when you get to this site to download.
Jul 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer stops and signals E20 error code
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
Jan 24, 2008 | Frigidaire Laundry Affinity 3.5 Cu. Ft....
Frigidaire Affinity ATF6000F Front Load Washer Logo
264 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
