Question about Dryers
I just moved in a house that has a 4 prong female outlet for dryer. So I just bought a 4 prong male plug, but I don't know what wire goes where in the back of my GE Two Cycle Dryer.
Posted by wsfd203 on
Mark Tabor
  • 31 Answers
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silvER.
3 Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
Posted on Sep 13, 2014
D. Floyd Kolb
  • Dryers Master
  • 43,501 Answers
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on May 11, 2011
3helpful
2answers
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 • Dryers
What kind of a plug in is needed for a dryer. My dryer has 4 prongs and my house outlet only has 3 prongs. I bought this house three weeks ago. I bought my washer and dryer when the gov;t. was giving...
Hi fran707al
If you already have a dryer receptical/plug then look at it closely and you can purchase a receptical/plug at a Home Depot type store or your local hardware store.
I will send you to a webpage that will show you how to wire a 3 wire or 4 wire dryer Circuit/Dryer
Free answer...Please take time to rate me
Hunter
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
May 26, 2011 • GE Dryers
2answers
I have a 3 prung male plug, and a 4 prung female plug. Can I switch the 3 male plug to a 4 male plug?
Hi, and yes you can, its done all of the time. You want to change the plug on the wall, not the cord. That is the way it is done. Very simple. Turn off breaker to the 4- prong. Go to any hardware store such as home depot and get the 3 prong 220 volt female plug, both are the same volts, just made for different cords is all. The male is on the cord. On the 4 prong female plug thats on the wall, just loosen all 4 screws. 2- wires are hot, either black in color, a black with a piece of white tape on it is the neutral, and a bare ground which is much smaller. When installing the 3 prong female, you will use all 4 wire to. 2- hot, ! neutral, and a screw for the small bare ground. There will be a drawing on how to connect the wires with the new plug if you are not sure. Normally, there are 3 black wires, 2 hot , 1 neutral. Some times there may be 2 blacks and 1 red. A black and red will be hot.I am sure they will all be black. The plug is marked on it. It will have L-1, L-2, N, and Ground. When you remove the 4 prong female, it will be marked the same. Be sure the power is off! L-1 and L-2 are hot, and the 3rd is N or neutral. Then the small ground. Very, very, simple to change and to know which is which. The terminals on the plug are colored also. The 2 that are copper colored are for the hot wires. The brass or silver is the neutral. And you will see the ground screw. I hope I haven't confused you, it is very easy. Just when removing the wires to the old plug on the wall, which should be a 4-prong female, the 2 wires on the right and left side of the plug are going to be the 2 hot wires. The other large black is the neutral goes to top or bottom, its marked like I said with a N. and a small bare ground. Always change the plug on the wall to fit the dryer from 3 to 4, or 4 to 3. They are both 30 amp plugs, 220 volt. Very easy, you can do this!! Please rate me on my help to you.
Sincerely,
Shastalaker7
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 • Dryers
1helpful
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
I just bought a used amana dryer that is 1 year old. it has a 3 wire pigtail and i have a 4 wire plug in and need to change out the pigtail. need some direction on if possible to change it out or will i...
go to the local hardware store and buy the male plug for the female plug that you have in the wall just hook up the three plugh in place of the 4 wire plug. The 4 wire has a netural and a ground which is the same thing and two 110 hot wires that are 110 v each, hook up the copper colored wires to the copper colered wires and the one ground on silver. screw or white to silver wire. this is Ground you only need one ground and if the plug on the wall is three prong it is go to use a three wire plug the third wire is for a backup ground on new systems
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
1helpful
2answers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
