Toshiba Regza 37HL17 37 in. LCD TV Logo
Posted on May 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change my pictue size using remote control
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on May 11, 2011
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006139
Points
237762
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
Need to change the size of the TV picture
Hi David,
There is key P Size on the remote control. Please use it and select the size of picture you need.
The picture exceeds the size of the screen and the outside of the picture is missing
Change the image size with the 'picture size' or 'format' button on the remote. On some tv's you have to go into the menus to change the size if there's no button on the remote control.
2answers
Please assist. How do I set my screen smaller on my Samsung BN59-00890A with my remote.
I think you are quoting the Remote Control number. What is the model number of your TV?
How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
How do I change the pixel size when taking pictues
Hello, Go to camera MENU, SETUP and set the quality of the photos to a lower setting to reduce the image size.
5helpful
How do you change picture size without the remote control
I have a 47 inch Toshiba lcd tv. I lost my remote control and am unable to change the picture size on the screen. Is there a way to change the hd settings from 480i to higher definition through my digital cable box?
How do I change the aspect ratio?
on the rca tv's its on the remote hand unit ,might be called zoom - or pictue, picture size.etc.if you can't do ti with the remote enter you menu on the tv set and look for it .
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
