Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
Hi My printer prints the document but frequently four black lines
will appear horizontally across the page equi-spaced down the page.
If I turn the printer of and put it on again it prints perfect for another 5 or 6 pages.
Can you help?
many thanks Ray
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
SOURCE: black line down the right hand side of everything I scan
it is problem your copier scaner mirror is derty
clean it
SOURCE: dell 3000cn color printer - black/grey line down
Sounds like the black drum. You can't get the part from anyone but Dell so be prepared for the cost. It also requires some disassembly to install on my Dell 5110cn so yours most likely will also.
