Question about Saeco Stratos Coffee Maker, Espresso Machine
Hello, my saeco stratos is showing over heated in display everytime I take steam.Can this be solved?
Posted by info75280 on
bansheracer
  • 1,089 Answers
Hi
When you are done steaming, just press the water button and open the steam valve again. This will purge the steam and cool the boiler back down. When it is cool enough the display will change back to "product ready for use". Have something under the steam wand as this is where the steam and water will come out.
Posted on May 11, 2011
Testimonial: "Thanks a lot!"
High pitch noise sound when brewing coffee
www.coffeemachinemanual.com/saeco-stratos
You might what to see if this is of any help.
Jun 24, 2014 | Saeco Stratos Coffee Maker, Espresso...
Decalcify jura
First run a Descale cycle from the menu (this will take several hours/overnight). Then hold the steam button for five seconds to reset the code. Good Luck!
Dec 27, 2013 | Saeco Stratos Coffee Maker, Espresso...
I don't have a manual and need to decalcify my saeco stratos. I know I have to buy a bottle of descaler. What do I do then?
Don't use vinegar or CLR or any chemical used in the bathroom. Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
  1. If you have a non-rapid steam machine, just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  2. If you have a rapid steam machine, turn on the machine and then push the hot water button. This turns off the rapid steam and allows you to run hot water/solution through the steam wand. Just open the steam valve and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes.
  3. Repeat step #2 for your type of machine. Do this until you have used the entire water tank of solution (approximately four to five cycles). Remove the water tank and rinse it with fresh water.
  4. Refill the water tank with fresh water and place it back on the machine.
  5. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set.
  6. Your machine has been decalcified. You may still have scale in your boiler, but not as much as you had before. To reset your descale light, hold down on the steam button for at least five seconds. You are ready to brew, once your boiler has heated up.
Oct 29, 2010 | Saeco Stratos Coffee Maker, Espresso...
Type: sup 015 st no water passes during rinse or
First, check / remove the water filter in the tank, next try to run hot water thru the wand, not steam but water, this should prime the system, then turn off and back on, that should do the trick, unless you have a bad pump. Good Luck!
Jun 27, 2010 | Saeco Stratos Coffee Maker, Espresso...
Machine wont make coffeee, m,essage says ventilate...
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
Saeco Stratos
Won't come out of Energy Saving mode.
Sep 08, 2009 | Saeco Stratos Coffee Maker, Espresso...
Saeco aroma compact SE 2GR turns on, but only heats the water.
I had replace my on off rocker switch on my aroma nero after a couple of years I was able to swap out my switch for heating the steam as a temporary fix I purchased a replacement switch from Sacco at that time but I think now you might have to go to a secondary parts dealer I have kept this machine a live for over 12 years and am now going back to it after fighting with my new automatic machine sure it was easy but the taste just was not the same the kids can have it they put so junk in their coffee how would they know [email protected]
Sep 05, 2009 | Saeco Aroma Espresso Machine
I have a problem how to do purgar
normally you open the steam valve that the way to purge the air out of the machine fill the water tank and open the valve to let air out pierre
Dec 27, 2008 | Saeco Stratos Coffee Maker, Espresso...
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : [email protected]
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Stratos Coffee Maker, Espresso Machine Logo
263 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
