Question about Logitech Inc MX610 Laser Cordless Mouse DH931350
No X/Y, guzzles batteries.
With the Logitech utilities, I can get it to associate, but never quite get that X/Y mousing action one hopes for.  Buttons work, though the LMB is really hard to press and the mousewheel doesn't look like it will tilt right properly (no room on the case!)  Ah, I should've tested it when I first got it.  Sure enough the screws to open it up are under the footpads.  Any advice on what to check/fix and how to put the pads back on?
Posted by Steve Nordquist on
5 Related Answers
Anonymous
SOURCE: Logitech LX-7 Wireless mouse
Buzzinator's diagnostic is right on. The microswitch has a hard plastic (as it should) while the pads on the pillars that reach down and actuate the microswitchs are of a softer plastic. For the left button, the notch is all the way across the pads while for the right button, the notch is still growing from one side, but still works.  I don't have epoxy either, nor metal tape (great idea!). So I filled in the notch with superglue! Bad choice, I know, but it's all I have at the moment.
Posted on Dec 22, 2008
NinaE
  • 3278 Answers
SOURCE: Logitech V220 Cardless Optical Mouse is not working
As long as you have installed the mouse driver, you have done everything possible ... the mouse is faulty.
Posted on Jun 25, 2009
Anonymous
  • 22 Answers
SOURCE: Wireless Logitech mouse with NO connect button
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Posted on Mar 18, 2010
TechMichelle
Maanita Clive
  • 77 Answers
SOURCE: My Logitech Wireless mouse stopped
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please refresh the wireless connection
in order to do so please press and hold down the connect button at the bottom of the mouse and the connect button on the receiver together and release both the buttons together.
this should referesh the wireless connection.
Posted on Nov 16, 2010
Testimonial: "It worked! Thx :)"
BabaMaarten
SOURCE: dropped wireless mouse and wheel shifted & buttons hard to push
I had a similar problem and was able to fix it. The left mousebutton was clickable, but needed extra force.
After opening the mouse I found that at the side of the mousewheel there was notch pointing upwards, preventing free movement of the left mousebutton. I was able to rotate the ring with the notch back into horizontal position after gently pushing the housing surrounding the mouse wheel wider.
Posted on Jan 05, 2011
Left and right buttons swithed fuctions
There are 2 places where the buttons can be switched.The first is the mouse chapter in your control panel. These settings however are overruled by the settings from the logitech mouse utility which you can also find in control panel or in the system tray (right bottom area). Use this utility for your desired settings.
Feb 05, 2011 | Logitech Cordless Mouse
Settings fcr buttons on the mouse
In control panel...hardware and sound...mouse.
or in classic view it is under "mouse"
But you may need drivers if you want to use the special features of a specific type of mouse.
Feb 01, 2011 | Computers & Internet
Logitech wireless rf keyboard and mouse quit
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
regards.
Jan 28, 2010 | Logitech Wireless Access Duo Optical...
Logitech LX8 Mouse back button quit working on AOL
This has been a long time problem with Logitech and Aol. If your mouse software allows you to edit your mouse buttons, change the back button to "keystroke" and enter the back arrow key on your keyboard as the command. Alt left arrow also works. While you don't appear to have a forward button, Aol users who do, would change it to "keystroke"...Alt right arrow.
Mar 09, 2009 | Computers & Internet
Morrowind
browse for some controller to mouse/keyboard software, you should be able to find tons on google, i use joy to key, just set up the buttons to keys you want to use, or set up the buttons randomly and redefine the keys in the game, also if you use a mouse in game you can set up buttons or joysticks to use the mouse on joy to keys
:) hope this helps
Jun 17, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Mouse doesn't turn on
This wireless mouse should have a transmitter that is plugged into the computer. Try replugging that in, and if there is a connect button on it, try pressing that as well.
Jan 29, 2008 | Logitech Inc MX610 Laser Cordless Mouse...
Optical mouse quit working on my notebook
I also had the same issue on my Vista laptop, having now uninstalled the latest Windows update for "Security Update for 2007 Microsoft Office System (KB960003)" my Belkin mini optical mouse is now working again.
What can I say other than "typical microsoft"!!!!!!!
Nov 02, 2007 | Computers & Internet
LX5 Cordless Optical Mouse - Rotation Function not working
Did you try checking the mouse settings via the control panel.
You should have some new software. In the logitech manager you will find a place to edit the mouse buttons.
Oct 11, 2007 | Logitech LX5 Cordless Optical Mouse
Computers & Internet Logo
48 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
