I have lost some of my channels on freeview. the area where i live is not due to switch over yet. all was working fine until i tuned in yesterday with no signal. i have reset my channels but lost quite a few - itv, channel 4, channel 5 etc
Jamie Andrew Knights
  • 244 Answers
You need to check your aerial,sounds like signal loss.
Posted on May 11, 2011
  • moonstar444 Jun 18, 2011
    Just had the same thing happen to my TV!!!
    Ariel leads seem ok ?!
  • Jamie Andrew Knights Jun 19, 2011
    What are your analog signals like
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
I Have a 15inch acoustic solution telly with built in freeview model number astv15id , however it has lost most of the freeview channels how do i retrieve them back.
Go into main menu set up and navigate to option to rescan. (might be called install or re-install stations)
Note - if it has lost channels it may be due to poor signal quality - check the quality of your aerial connections. You may also have lost channels if your area has recently been subject to 'digital switch-over' . Although they are already on digital tv all Freeview boxes will need re-tuning after switch over because this entails a change of some channel frequencies post analogue.
Feb 26, 2011 | Music
Technika TV Tuning Problems
hi the same happened to mine. a22inch freeview dvd.wont pick up a signal when tuning in.Its had very little use ( 150hrs ish) as its in our caravan. we now plug in a separate freeview box via the scart.Tesco dont want to know as it was 3months out of warranty at the time of complaint.Anyway Im meeting Tesco in County court in july. It appears to be a common fault
May 13, 2010 | Televison & Video
I now cant get bbc 1,2 ,3, on my free view box it wont tune in
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 12, 2009 | Televison & Video
No BBC channels available after retuning Sony Trinitron TV
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Since retuning my Sagem DVR6200T/6400T settop box I have been unable to receive BBC channels. I am using the default code 0000. Can you please advise. W M Fitzgerald MK17 8DJ
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing.
Nov 07, 2009 | Televison & Video
My daughter can't get BBC1, 2 and 3 since 4 November. Signal comes from Winter Hill. My TV is a Goodman (with built in Video)and my freeview is a Pace. My Pace system automatically searches but misses...
Nov 06, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Fault
as long as you have a good digital aerial connected to the recorder and you are in a good signal area then the channels should have been found automaticaly and stored on the machine.. a manual search and store would also work ok.. check your aerial connection/aerial type and any info you can find on freeview availabiliy in your area.. do you or anyone in your area have any other freeview device running ok?
Jul 28, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Ferguson fst
Hi.
Connect the freeview box to tv using scart lead tv will automaticaly change to freeview channel when digibox is switched on if you connect this way so no tv tuning will be required.
Jun 01, 2008 | Televison & Video
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
