Question about HP LaserJet 9050 Printer
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Posted by nlheng on
Seeker5211
    Genius:
  • 1,089 Answers
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
Posted on May 11, 2011
Hp 9050n ip address
Go to the config device menu and scroll down until you see ip settings. From there select manual settings and you can retype from there
Feb 17, 2014 | HP LaserJet 9050n Printer
I have got hp printer error 60.02 plz help me.
Tray 2 is not lifting the paper.
Open the tray and look for obstructions.
Remove and reseat the tray.
Try switching trays 2 and 3.
If that doesn't work, reply back to me.
Feb 28, 2011 | HP LaserJet 9050n Printer
LaserJet 9050n with error 59.40shows when printer is turned on - sometimes I get a 59.30 Tried reseating the fuser, but it did not help
This is a main motor error.
Most commonly I have had Toner Cartidges sieze up and cause this error.
Otherwise, it could be caused by a faulty motor or DC Controller PCB
Dec 21, 2009 | HP LaserJet 9050 Printer
49.4401 service error on start up
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 19, 2009 | HP LaserJet 4650dn Printer
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Eror message 49.4401 on hp clj 5550
Dec 15, 2008 | Office Equipment & Supplies
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Hp laserjet 4550dn, how do you initialize thehard drive?
Try taking the disk out and format it on a PC first.
Aug 08, 2006 | HP Color LaserJet 4550dn Printer
HP LaserJet 9050 Printer Logo
2,773 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
