Pentax ME Super 35mm SLR Camera Logo
Question about Pentax ME Super 35mm SLR Camera
Rewind button on bottom of camera is stuck in a depressed state and will not release. This causes me to be unable to rewind or load film, shutter button will not cause shutter to click, film advance crank will not pull. How can I release the button so my camera works again?
Posted by a_oneill86 on
Anonymous
    Sergeant:
  • 304 Answers
Sounds like your camera could use a cleaning and oiling, I'd suggest sending it off to Gus Lazzari for repair. He does good reliable work to film cameras. Hope this helps.
Posted on May 10, 2011
Asahi Pentax Spotmatic SP The film rewind button is fully depressed and won't pop out, and the shutter button isn't working.
if the camera is jammed for any reason, then the rewind button will not pop out. on this model it was common that the mirror cock lever at the bottom jumped. in which case the camera will jam up.
remove three screws holding the bottom cover, remove cover. in the middle of the camera is a lever that needs to be latched by pushing it forward. the camera should release and revert to normal usage.
if this is not the case then there may be something jammed in the winding or shutter gears. in which case you would have to remove the top cover and/or front covers.
2helpful
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Rewind stuck on reverse
Hi Luce n Steve, To quote JC at Photo.Net: "sometimes the rewind function "gets stuck" if the camera thinks a previous rewind did not complete successfully. The solution is to reset it by forcing a rewind operation. Just press the two rewind buttons simultaneously: on the left side of the lens and just behind the shutter release. (They are marked and the manual explains how to force a rewind.) I did exactly this, and my next roll of film loaded without problems." Hope that help you folks.
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
1helpful
Film Rewind Button Problem!
mistermanage,
turn the advance lever to charge the shutter.or open the film door and rotate the drive sprocket to the right, this will release the button. if the button didn't pop up then the bottom cover will have to be removed in order to release it manually.
Film wont rewind
nadyne,
manual rewind is next to lcd panel right side. hold the button down for 3sec. the re-wind symbol will be displayed on the lcd panel.while holding down the re-wind button depress the shutter button. film will re-wind.
1helpful
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
3helpful
2answers
XR 7 locked up
Just read on another forum where the film rewind button can get stuck (little button on the bottom of the camera, used to initiate rewind), and removing the camera bottom allows access to unjam it.  I'll try... takes a small philips eyeglass screwdriver and young eyes (or my reading glasses...)
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
2answers
Nikon F60 Film rewind uncoded film help
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
Top Pentax Photography Experts
Steve
Are you a Pentax Photography Expert? Answer questions, earn points and help others
