Go to task Manager > processes tab and find the StorageSync program and end process. Unplug the drive, shut down the PC, replug and start up the Pc and try again.
Typically back-up files made by back-up programs are encoded, and depending on which back-up software this may or may or may not allow you to access the backed-up files individually. How you access your backed up files will also depend on the back-up software you use.
This procedure should work for any back-up software.Copy your back-up. Restore your back-up to a new location. Access the files you want from the restored back-up. Now you have access to the files in the back-up as they were when they were made, while still retaining your back-up and your current files. Be careful not to confuse 'old' for 'new' and 'copy' for 'original'.
If you are asking how to restore a Time Machine backup, you will need to connect and turn on your drive, then open Time Machine, navigate to the drive, highlite the backup and click on the restore button. It should then restore the files from your backup.
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same.
http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Backup software compresses the files and encodes them to an image file made up of a series of sequenced files. The same software you used to do the backup should have the restore options needed to locate desired files. SimpleTech website shows Fabrik to be the name of the backup software.
If you utilized, there's also an online backup site used to store files. Following link is the users guide: http://www.simpletech.com/support/guides/user-guides/60000-00168-001.pdf
The BPA files are the backed up copies of your data. The simpletech utility backs up your files to compresse file ending in BPA. Any computer running the simpletech restore program can extract the data from these files.
You will simply need to install this software on a spare computer in order to test the backups. Frankly though I would just use windows backup to copy the files/folders you want to the drive raw as this can be read anywhere.
Since I don't know what you're clicking, I can only tell you that you need to choose the "Incremental Backup" radio button at the bottom left of the Backup Window, then click the "Backup" button.
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
