When you press the power switch on your laptop, the lights turn on only for a few seconds then they shut off? It will not power on at all?
Make sure that your battery has a charge. Leave the laptop plugged in for 10-20 minutes and see if it will power on after that. If not, you have a couple of options to try.
-Try a different laptop battery. The one you have may be damaged.
-Try a different power cord.
-Try a different wall outlet.
If none of the above solutions work. you may want to contact Dell technical support for further assistance.
Click here for dell tech support
Regards,
G33k
SOURCE: My DELL laptop display goes off after few minutes
read up on your manual on how to shut off the monitor (so that you can use an external one). it may be toggling on. other options are to make sure you have the newest driver and also to shut off the screen saver function. does this happen when you are plugged into the mains or just when you use battery ?
robert
Is the battery in? Is it charged up?
