Yes it has a pump.............
move machine to an outside door and let drain hose lay outside to get rid of some water........
remove back from machine...........the drain hose connects to the pump....
so .follow drain hose back to the pump then ........
see if you can open it up to unblock it.........
cheers
Posted on May 10, 2011
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
Dec 29, 2013 | Kenmore Washing Machines
May 02, 2011 | Washing Machines
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Feb 04, 2011 | Tricity Bendix Washing Machines
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Aug 26, 2009 | Washing Machines
Mar 16, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Sep 12, 2008 | Danby DWM99W Top Load Washer
