SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on. If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
SOURCE: how to set up my vizio VF550M on 1080p its on
The TV will display what you feed it, the source dictates the resolution.
SOURCE: I have a Vizio 37 inch lcd tv. It works fine from
Well It depends on what you mean by fade out, Fades out completely or just darkens enough to be annoying? I just bought this exact tv and mine also fades, I changed the preset picture function to "game" mode and the fading stoped.
