Question about Sherwood Audio Players & Recorders
I would like a manual for a sherwood rvd 6095 rds please
Posted by roy9426 on
Stelios
    President:
  • 1,851 Answers
Here is an official link for you to download the requested user manual. Note that the user manual for RVD6090 and RVD 6095 are the same, according to the Sherwood USA (take a look at this link, at the Discontinued Models you can locate the same manual for both devices)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 10, 2011
wswift
    Scholar:
  • 74 Answers
Here is the manual, direct form the manufacturer.
Click here.
Sherwood RVD-7090RDS when turn on can hear relay click sound but no display
Chances are you have a bad power supply rail that feeds the display, generally its different than any other voltages
Mar 23, 2018 | Sherwood Audio Players & Recorders
I need user manual for a sherwood RVD-9090RDS
hi,
I have the user manual for sherwood RVD-9090RDS with me. As it is pdf file i can't sent the same through the Fixya. If you can provide your email id then i will sent the same to you email address.
OK
Sep 11, 2011 | Sherwood RVD-8090R Receiver
The sub-woofer output on the receiver is not working. I have tested the sub-woofer (speaker) and it works. And I have tested the cables and they work. The problem lies within the receiver. How can I fix...
I don't have the manual, but if YOU do, crack it open and find the part where you tell the receiver it HAS a subwoofer and any other settings that direct bass toward it.
Apr 18, 2010 | Sherwood RVD-8090R Receiver
While watching a movie the reciever shuts itself off after several minutes.
Please note exactly after howmany minutes.
If you cannot determine the exaxt time the reciever switchoff.
may be any component on the mother board gets heated up or dry soldered.
try to solder the component.
Jan 10, 2010 | Sherwood RVD-6090R
Looses all preset radio stations when power turned off.
There is a small battery inside somewhere that keeps the presets. It probably needs replaced.
Nov 04, 2009 | Sherwood RVD-6095R Receiver
Sherwood RVD-9090R Left Rear Channel Failure
its due to your player there is nothing wrong with fuse... don't crack the case...try this just connect M1 & M2 to the aux input of your home theater
May 23, 2009 | Sherwood RVD-9090R
No High Voltage
I did solve the problem with the Sherwood receiver R6036-R
The problem was a broken solder Trace towards the power cord on the powersupply board.
Thanks for your concern
May 30, 2008 | Sherwood RVD-6095R Receiver
No power
my be the off/on bottom is not good.no working.
Jul 28, 2007 | Sherwood RVD-6095R Receiver
1,913 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rhodesworks
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
