Question about HP DeskJet F4280 All In One Printer InkJet
When I print a letter two lines only print half.
Posted by gendavi on
Reparatii PC - Service IT
  • 2,574 Answers
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
Photosmart C7280 only prints half the letter/line the part that prints is perfect but I would like the rest of the letter. Is the printhead out of position?
The print head is dirty, of defective.
Try a few cleaning cycles (the hp tool kit is in your HP program menu)
If this does not improve you image, replace the print head
Jan 07, 2011 | Office Equipment & Supplies
The top half of letters on certain lines of print are offset by about half a letter space from the bottm half of the letters. Usually but not always the same lines. help please
This usually indicates a need for a new print cartridge or the printer head is dirty. You can run the automatic printer cleaning utilities. Note: do them several times.
Also, if you are a little handy, use Qtips and rubbing alcohol and clean the print head.
Sep 18, 2009 | Epson LQ-590 Matrix Printer
Prints complete lines with occasional lines half height of letter
Your printer cogs may be damaged or your paper rollers could be slipping resulting in this "odd" output.
Paper rollers can be cleaned with an appropriate cleaning kit but if the cogs are damaged it's not worth repairing.
Jan 22, 2009 | Epson Stylus CX6600 All-In-One InkJet...
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Nov 23, 2008 | HP Photosmart 8450 InkJet Printer
L7780 won't print on edge of paper
it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
Sep 12, 2008 | HP DeskJet 5740 InkJet Photo Printer
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
HP DeskJet F4280 All In One Printer InkJet Logo
141 people viewed this question
Ekse
efs_perpends
efs_perpends
