Question about Kenmore HE3T Washer
Apears the code fdU and dont let go the water and make a funny noise
Posted by vicristo on
Jeff Rockwell
  • 5,911 Answers
"FdU" is a Door Latch Unlock error code. This is usually an indication of a failed door latch, a Central Control Unit (CCU) problem, or the interconnecting wiring between the two. The first step in troublehsooting any error code on these model washers is to press PAUSE/CANCEL to clear. If the error remains, UNPLUG the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit. In many cases, resetting the CCU will correct many momentary glitches in the program operation. If the error returns following a CCU reset, then you have a legitimate problem. The following link explains the door latch error and what you can do to troubleshoot:
http://www.fixya.com/support/r4490349-fdl_error_code
I know the link is for the "Fdl" error, but the symptoms, troubleshooting and remedies are identical. I have included web links for part resources (if required).
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on May 10, 2011
I don't have connection between the Thuraya phone and the FDU-XT
you can use The FDU-XT , because Thuraya XT can not use in the room , you can only receive the satellite signal outdoor . please see attached FDU-XT , Thuraya Docking station with outdoor antenna , which made by Huayang Technology , Brand Name : Matsutec.
www.huayang-tech.com
Jan 11, 2014 | Thuraya FDU- XT Fixed Docking Unit
My washing machine is making a funny noise when it spins
well this is not very help full, funny noise's? hhmm? ok, cat stuck in the drum? no? lets try the bearings wearing out or braking up? broken spider? yes i did say spider, its the bit that holds the back of the drum to the driving shaft!! maybe you left a coin in a pocket and its found its way behind the drum, lets hope it dont find its way into the pump as well! broken suport springs? any number of other things????? but as for funny noise's,,, im stumped now,,oh, yes, just the one spring's to mind! my dog snores??? but he's no a very good washing machine!!!!!!!!!!!!!
Oct 20, 2009 | Washing Machines
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Kenmore HE2 110.4751
for the F10 code ? Unplug the washer open chech the funny noise / belt are worn out / slap to the brackets and other near obstacles . Replace belt broken.
Detergent leaking /ovewr flow clean w/ fish nylon # 150 just 40 cm /insert in the hole put water to soften the hard detergent forward and backward to clean detergent hose.
Nov 15, 2007 | Kenmore 43142 Front Load Washer
Kenmore HE3T Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
