Wahl The Peanut Hair Trimmer Logo
Posted on May 10, 2011
How do I take the blade off - Wahl The Peanut Hair Trimmer
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on May 12, 2011
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
21742
Points
48
Hold the peanut trimmer in one hand, place a your thumb on the blade with a wash towel pull the blade back, it should pop off. When replacing the blade, the blade has a plastic notch on the bottom where is round, insert that notch into the square hole on the trimmer and push back. it will snap on.
Changing blade on Ryobi chop saw
Unplug the saw. If the blade is moving, wait for it to stop. If the blade arm is locked into its down position, push down slightly on the blade arm to release the tension on the blade arm lock pin. Pull out the lock pin to release the blade arm and allow it to move upward.
2 Rotate the lower blade guard upward and expose the Phillips-head screw that holds the blade bolt cover in place. Loosen the screw and rotate the blade bolt cover up and out of the way to expose the hex-head blade bolt.
3 Push the spindle lock button in and rotate the blade bolt until the spindle lock engages fully, stopping the ability of the blade bolt to rotate.
4 Loosen the blade bolt using a 10-millimeter/12-millimeter combination wrench. The blade bolt is lefthand threaded, which is the reverse of conventional threading. Turn the bolt clockwise to loosen and remove it. Note the placement of the outer washer and remove it as well.
5 Place a drop of machine oil on the inner blade bolt washer. Do not remove the inner washer. If it is missing, replace it before replacing the blade.
6 Slide the replacement saw blade up past the lower blade guard and onto the blade spindle. The blade teeth should point downward at the front of the saw. Saw blades often have rotation arrows that can help you double-check that the saw is installed to rotate the correct direction.
7 Press the spindle lock button in to lock the spindle and reinstall the blade bolt. The blade bolt will tighten in a counterclockwise direction. Replace the blade bolt cover and install the blade bolt cover screw.
8 Position a combination square to check that the blade is square to the saw fence and saw table. If the blade is not square, refer to the procedures in the manual for squaring the blade to the fence and table.
Things You Will Need
  • 10-millimeter/12-millimeter combination wrench
  • 5-millimeter hex key
  • Combination square
  • Phillips screwdriver
  • Machine oil
Tip
  • Overtightening bolts and screws can result in cross-threading. Cross-threading damage compromises the integrity of bolts and screws and can be a difficult error to correct.
Warning
  • Do not attempt to install a blade that is too thick in the saw. If the blade washer cannot engage the flats on the spindle, the blade is too thick for the saw.
Jun 12, 2018 • Ryobi Saws
2answers
I have a bosch jigsaw and the blade keeps slipping out of the roller blade guide after it runs normal for a few seconds. ive reset the blade and changed it.
Hi Rebecca, I hope this helps;
BLADE INSTALLATION
Set the blade orbit selector lever to position III.
Push blade change button downward as far as
it will go and turn the top handle three turns
counterclockwise (viewed from the top of the
tool).
Insert the blade into blade plunger at a 90°
angle to the cutting direction. With a slight
upward pressure, turn the blade teeth forward
(direction of cut) and guide the back of the
blade into the groove in the center of blade
roller guide. Pull gently down on the blade to
seat the blade tabs in the plunger.
With the blade in the proper position, turn top
handle clockwise until a noticeable "Click" sound
is heard, indicating that the blade is locked in
place.
Push blade change button upward to its
original position (flush with the top of the top
handle), and the saw is ready for use.
Removing the blade is essentially the reverse
of the installation procedure, however, take
note that once the blade change button is
loosened, gently push the blade upward to
release the blade tabs from the plunger.
Feb 13, 2017 • Bosch Saws
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
3helpful
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
1helpful
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
1helpful
Dont know how to install blade
on blade you will notice two small phillips head screws. remove both screws with thumb on blade. with other hand remove the blade. Blade has two parts. The smaller blade lays on top of the larger blade. align two blades together. Hold the blade compartment in your hand upward with smaller blade on top of the larger blade. On the clipper in between the two hole where screws go there is a small arm with a round shaped tip. Put the base on to the blades a fixing the round shaped arm into the blades ensure proper fitting. With hand holding the clipper turn over while thumb is holding the blades in place and replace screws.
3helpful
2answers
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 • Saws
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
