Check your CPU make sure its placed correctly and that you don't have too much contact grease,you only need a very small amount. If that's not the problem try re-seating your ram and video card. Other then that look at the power supply could be under powered! hope this has helped
Three beeps. " Memory error". Remove your system memory than reseat it. Make sure you here the locking tabs click closed. Your board uses the Award bios. Open the link; http://www.bioscentral.com/beepcodes/awardbeep.htm
Using the manual for the Gigabyte GA-945P-S3 MB.
Go to page 71 & you'll see bios beep codes for your board:
AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
As you can see there isn't a code for three short beeps.
When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system.
Bios codes from the link below.
http://www.computerhope.com/beep.htm#05
3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11
You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory.
This should help.
Thanks for using FixYa!
Mike
hello
My mother has the same motherboard. It's
been a long time since we had bought in a bazaar, as an old piece of
scrap that will be sufficient for my mother to surf the Internet and
start with a computer.
But after some time, my mother began to paint in Corel and Photoshop, and she began as a teacher to produce a school magazine.
And that's the motherboard scrap really scrap.
First, I swapped memory.
And when I swapped the memory and turned on the pc again, so I had the same problem as you.
But the solution is not so complicated .. So how to get rid of beeping sound after you improved a hardwear?
Turn
off the source, after unplug the network card (you do not remove it
out, just pull the cord RJ14), as well as all USB connections (these
mainly) .- As the old motherboard and simply not do it all at once.
After
that you should turn on the computer without problems, run the plug
again network cable and all USB and printer, and restart the system to
save the settings.
I
recommend download the latest BIOS and Install the
http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=2307
After the motherboard does not have problem to boot after change hardwear.
After the motherboard can handle athlon 3000 and will be able to plenty else.
Now that everything is in the manual which can be downloaded from the same side as bios and other drivers.
