TDK Trans-IT 8gb flash drive is unable to format. It gives an error that says this disk is write protected, please assist.
    New Friend:
  • 8 Answers
Get a copy of the software from TDK itself at:
http://www.tdk-media.eu/downloads/trans_it_usb_password_pr_english.exe
it's a self contained .exe file no installation needed. This will format your flash for you if you need to and the program gets retained.
if you want a pc based format copy the software somewhere in your hard drive. in myu computer right click your flashdisk, format (fat 32 better). There clean as a whistle. copy back flashlock, then partition as you wish.
Posted on May 10, 2011
6ya staff
SOURCE:
I am unable to format my new 8gb sandisk Can you
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Sep 18, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a TDK 8GB , i lost my password , so i cant access to entire space on my disk,how can i totally format my flash memory?
Hello and Good Day!
Maybe this will help,first click start button located in the lower left corner of your desktop then click My computer, at the my computer window locate your flash drive perhaps it is labeled as TDK or removable drive then right click using your mouse,look the word "format" left click at the lower part of the window you'll see quick format click the box then click start.
Hope it helps Thank you
Jun 09, 2011 | TDK (CD-RW74HSFXS5) Storage Media
The flask card was formatted and the lock too.
TDK-branded USB drives with built-in TRANS-IT security.
"Flash Lock" password system security:
TRANS IT USB Password protection software (english)
Feb 02, 2010 | Electronics - Others
I have mistakenly formated my TDK 8GB TRANS-IT FLASHDRIVE and altough it is empty it looks only 9.95MB capacity. Any suggestion to solve this?
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it.
Try formatting using Disk manager.
Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Dec 19, 2009 | TDK (CD-RW74HSFXS5) Storage Media
8gb TDK trans-it flash memory is invisible
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 18, 2009 | Imation Products - imation - Clip Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is [email protected] kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Only 5GB on TDK TRANS-IT USB 2.0 Flash Drive 8GB
Not the solution you might like but there have been reports of bogus/ counterfeit smaller capacity sticks/drives relabeled and programed to report higher capacities. I've been told that running a formatting/partitioning application on them reflect the true capacity but have not had to try this solution myself..
Submitted for information only but please rate so I accumulate a lot of unanswered solutions, Thanks
Mar 15, 2009 | TDK (CD-RW74HSFXS5) Storage Media
TDK usb flash drive 8GB can not hold more than 5GB
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format Flash Drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | TDK (MF2HD50PK) (50 Pack) (TDKMF2HD50PK)...
Computers & Internet Logo
1,807 people viewed this question
Ekse
Marvin
Marvin
