Question about Philips GoGear SA2RGA MP3 Player
How do I know when the battery is charged - Philips GoGear SA2RGA MP3 Player
Posted by summersr on
Michael Wafkowski
    Master:
  • 346 Answers
Hello - Your player is charged when the battery icon on the display stops it's animation and the battery icon with a lightning bolt through it is displayed.
Thanks for using Fix Ya and enjoy your music.
Mikeywaf
Posted on May 10, 2011
My renegade 50cc scooter will not charge battery
If you have shorted the polarity of the battery, you have probably damaged a diode in the voltage regulator...You should be showing better than 13 volts DC at the battery terminals while the engine is running...Use a digital meter to check it.....If you unplug the harness coming from the engine to the Voltage regulator...You should be showing better than 50 volts AC at the engine harness while the engine is running...Be sure your meter is on AC setting when testing the stator harness...Also be careful doing this test as a possibility of electrical shock exist...Be careful not to short any terminals.........
Oct 21, 2018 | Motorcycles
Problem with mobility scooter
have the batteries load tested first
Jan 24, 2018 | Health & Beauty
2003 Ford Taurus will not start. Have tried jumping the battery but still nothing. When turned on, all dash lights come on and then there is a click sound when we try and turn it over.
2003 taurus not starting the lights on dashboard not coming on.windows wont go up and wont crank ..anyone know what to do ..please
May 14, 2012 | 2003 Ford Taurus
How do you know the state of the built in battery charge. also how do you know if it charging when pluged into the mains
Hi, If the battery does not charge properly. The battery in the unit maybe the problem. Replace it.
After a long time of use the battery will not hold a charge.anymore. Good luck.
Jun 24, 2011 | GPS
I have HP PavilonDv4000.My batery show charge 96% total time remaning 5min.I have new battery first chrge the battery fully.Second,discharge the battery completely.And this battery can't be charge any...
Try another known good working battery and if it doesn't charge and hold the charge properly,
If that doesn't work, try another know good working ac adapter to see if it is actually charging the battery properly.
If that doesn't fix it then you know for sure at that point the motherboard is bad.
May 31, 2010 | HP Pavilion zd8000 Notebook
Looking for an instruction guide for a ''Challenge'' jump starter for Cars. The red switch on the model has three positions OFF/CHARGE/ON. I need to know which switch is to recharge the car battery and not...
The 'ON' position is for charging OR jumping the car battery. Normally, you just hook the unit to the car battery to jump start it, then remove it and the car alternator will charge the car battery.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 26, 2009 | Black & Decker Simple Start Car to Car...
Battery doesn't charge.
the power supply may not be delivering the necessary power to charge your battery.
Jun 02, 2009 | HP Compaq nx9600 Notebook
I don't know how to charge my battery
Its ok. Um just leave the battery plugged into your laptop and the power cord plugged into the laptop as well and the laptop will charge it for you. If it won't, the battery is no good and get a new one but you don't need a external battery charger to charge your laptop battery.
Nov 21, 2008 | Dell Latitude D600 Notebook
Charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
Nov 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Philips GoGear SA2RGA MP3 Player Logo
70 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
